Area of trapezoid formed by slicing a cylinder
The discussion centers on determining the area of a trapezoid formed when a cylinder of radius R is sliced by a plane at an angle α. Participants explore the geometric implications of the cut, noting that the shape may not be a true trapezoid but rather a truncated ellipse with curved sides. The relationship between the area of the trapezoid and the cylinder's dimensions, including the base area (Abase=π*R²) and the path of magnetic flux, is examined, with suggestions to use integration techniques for accurate area calculation. The ambiguity of the problem is acknowledged, particularly regarding the definition of the trapezoid's dimensions and the projection of the inclined cylinder. Ultimately, the discussion highlights the complexity of visualizing and calculating the area of the resulting shape from the inclined cut.
magnetpedro
What is the equation of the area of the trapezoid when a cylinder of radius R is cut by a plane inclined at an angle α? (Orange area of the figure)
How can I relate it with Abase=π*R2 or with Ainside=2*R*L?
Any hints please?
Thank you very much in advance.
Mathematics news on Phys.org
Any hints please?
That looks pretty straightforward unless I'm missing something. Have you taken trig yet? :smile:
Yes, I think I have but, unless I'm not grasping the whole problem, it's not quite simple.
I know that one of the sides of the trapezoid is 2R, but I don't know anything else.
I first thought that the length of the trapezoid would be L*cosα, but I think taht L*cosα it's only the projection of the length of the trapezoid in the xy plane (the plane of the screen of the computer).
Draw a line from the center of the left end of the cylinder to the center of the chord on the right end of the cylinder. Using the angle ##\alpha## you should be able to use trig to find the vertical distance (h in the figure below) between the central axis of the cylinder to the center of the chord.
Once you know h, you can find the coordinates of the chord on the circular end of the cylinder.
I don't think the orange region is a trapezoid. If you imagine extending the cylinder in both directions, the orange slice extends into an ellipse (get a sausage, cut it on the diagonal and look at the face you expose). Reducing the cylinder back to its original length simply trims the ends off the ellipse. So the ends of the shape are straight lines, but the sides are curves. Integration may be needed.
Likes certainly and micromass
Any hints please?
It's not clear what you are calling Abase.
In any event, if you constructed a true size view looking directly at the plane cutting thru the horizontal cylinder, you would see that the long sides of the "trapezoid" were not straight lines; in fact, these sides should be curved, possibly parts of a parabola.
One end of the "trapezoid" has length 2R only because of its vertical position on the end of the cylinder. At the opposite end, the length of the "trapezoid" is less than 2R.
If you make a series of cuts along the length of the cylinder, you can calculate how wide the "trapezoid" is at any arbitrary point. If you have the width at the ends and in the middle of the cylinder, you can use Simpson's Rule to calculate the area pretty accurately.
Can you give us some context to this question? Is it for a real-world application, or just a curiosity? Or is it for schoolwork? Thanks.
I would integrate with respect to the height of the "trapezoid," i.e. ##A = 2\int_0^H w(x) dx ## where H is the total height of the shape and w is the half-width of the "trapezoid".
If you can get it into the form of
## A = m\int_0^H \sqrt{c^2 - x^2} dx ##
then the integral evaluates to:
##\frac m 2 \left( H \sqrt {c^2 -H^2}+c^2 \sin^{-1} ( H/c ) \right) ##
I had to look that one up, so maybe it'll save you some time.
Likes magnetpedro
My interpretation of this problem, which could be wrong, is that the diameter at the left end of the cylinder and the chord at the right end, define a trapezoid. In my interpretation, it's immaterial whether the nonparallel sides of the trapezoid are inside the cylinder or outside it.
The problem is somewhat ambiguous. The OP originally had "Area of ellipse..." in the title, but in post 1, asked about the area of the trapezoid. I changed the thread title to be consistent with the question in post 1.
Yes, of course. It's a model for a real-world application.
Imagine a magnetic flux (or any type of flux, for that matter) that passes through that cylinder.
If the cylinder's axis is parallel to the x-axis and parallel to the magnetic flux vector, the area crossed by the flux is the Abase=π*R2, and the length of the path of the magnetic flux is L. On the other hand, if the magnetic flux vector is orthogonal to the cylinder, the area crossed by the flux is Ainside=2*R*L and the length of the path of the magnetic flux is 2*R, it's diameter.
Now, when the cylinder is inclined with an angle α to the x axis, the magnetic flux through the cylinder must be decomposed in two parts:
-one is the projection of the cylinder in the x axis, where the area crossed by the flux is the area of an ellipse (Abase/cos(α) and the length of the path of the magnetic flux is L*cos(α);
-the other is the projection of the cylinder in the y-axis (orthogonal) where the area crossed by the flux is in my opinion the area of the trapezoid that I want to find (and that I need/I think to have a sin(α) in the expression) and the length of the path of the magnetic flux is L*sin(α);
Thanks for your help.
It was my mystake, the new titles fits much better. Thanks!
Abase is the area of the base of the cylinder, hence π*R2.
Your chain of thought is similar to mine, but I've lost myself along your description. Could you be so kind to give me some start on the expressions?
As I said, I think that the area of the trapezoid is somehow related (or I wish it'd be for a matter of easyness of the treatment of the expressions) with the sin(α).
I'm sorry but I don't understand. When you consider w the half-width of the trapezoid, are you referring to the length of the base of the trapezoid? In this case which base? The minor or the major?
It's actually the projection of the inclined cylinder on the y-z plane. (the side view)
The projection is in the x-y plane (the top view). What you're doing is cutting a straight cylinder with an inclined plane and taking the projection of the cut-section. As I understand it, what you want is the projection of a cylinder that is inclined. The two are very different things! Think about viewing a cylinder that is inclined with the x-axis from the top versus what you were doing. The top view of a tilted cylinder is simply a rectangle with sides ##2R## and ##Lcos(\alpha)##.
In my breakdown of it, I was calling w the half-width of the short side of the trapezoid.
I see and agree.
In that case my only last question is what is c.
Would both of you care to explain, exactly how is the section of the cylinder relevant when you're actually tilting the cylinder itself ?
Likes magnetpedro
Imagine slicing the tilted cylinder from one base to another. That's how the flux "see/crosses" the cylinder when it is tilted.
?? As lbix pointed out. The plane figure is not a trapezoid but a truncated ellipse. ??
---Unless it's the trapezoid contained within the truncated ellipse that is of interest.
magnetpedro said:
I see and agree.
c is a constant for the formula, just like m. When I worked it out, it ended up being some combination of initial parameters R and sin(alpha).
Likes magnetpedro
In my opinion it is not. It's a trapezoid because a flux would cross all the length of the cylinder.
Here is my attempt at explaining why the cut-section won't be a trapezium:-
When the cutting plane is horizontal the section is obviously a circle.
When the plane is vertical the section is again obviously a rectangle.
Now imagine we start with a plane that is completely horizontal (lowermost cut) and slowly tilt it until it becomes completely vertical. At first you will get ellipses (upper 2 cuts)
Now if we keep tilting the cutting plane, at one point it will cut one of the bases of the cylinder as well and one curvy end of the ellipse is as ibix says "trimmed off", even more tilting, and the cutting plane will cut both of the bases, as in the original picture, and both the ends will be trimmed off, however the other two sides still remain curved, and they will continue to remain curved until the cutting plane is completely perpendicular. The only difference is, is that as you keep tilting the cutting plane their curve is becoming less and less apparent.
P.S. I still can't see what all this has to do with your original problem.
Likes magnetpedro
Now if we keep tilting the cutting plane, at one point it will cut one of the bases of the cylinder as well and one curvy end of the ellipse is as ibix says "trimmed off", even more tilting, and the cutting plane will cut both of the bases, as in the original picture, and both the ends will be trimmed off, however the other two sides still remain curved, and they will continue to remain curved until the cutting plane is completely perpendicular. The only difference is is that as you keep tilting the cutting plane their curve is becoming less and less apparent.
I understand your point, and it has kept me thinking for a while. Non the less, imagine this as shown in the picture,
These arrows represent the flux crossing the cylinder, so it has to cross all the cylinder.
Which is why I said in my first post that you should be thinking about the area of the top view of the whole cylinder and not the area of the cut-section.
Still, I don't see how this bears any relation to your argument that the area of the cut-section is a trapezium.
Likes magnetpedro
Perhaps you were right, but in any case, how can I relate this area that is crossed by the flux with the angle a?
Thanks a lot for your help once again.
see post #14.
Above is a quick plot of the trapezoid cut from a cylinder using R = 2, L =2, alpha = 30 degrees. The outer lines represent the actual width of the cylinder along the path, while the inner lines represent the straight trapezoid.
Once you work out the required trig to find the proper values of your variables, this either reduces to a simple expression (trapezoid), or the integral I posted above (truncated ellipse).
You can draw right triangles everywhere to find the right values based on R, L, and alpha.
Likes magnetpedro
This is awesome. Have you done it in Matlab?
Would you be so kind to lend me the code you've used?
Here is the code I used in Matlab. It is not elegant, but does the trick.
r = 2;
alp = pi/6;
L =2;
H = 2/cos(alp); %length of trapezoid
h = 2*tan(alp); %height from middle at opposing side
w = sqrt(r^2 - h^2); %half-width at opposing side
x = linspace(-r,r);
y = zeros(size(x));
for i = 1:length(x)
if x(i) < -w %left edge
y(i) = H/(r-w)*(x(i)+2);
elseif and(x(i)>= -w, x(i) <= w) %top
y(i) = H;
else
y(i) = -H/(r-w)*(x(i)-2); %right edge
end
end
end
y2 = linspace(0,H);
wplus = sqrt(r^2-y2.^2*sin(alp)^2);
wmin = - wplus;
plot(x,y) %trapezoid
hold on
plot([-r,r],[0,0]) %bottom line
plot(wplus,y2) %right side cylinder
plot(wmin, y2) %left side cylinder
hold off
Likes magnetpedro
r = 2;
alp = pi/6;
L =2;
x = linspace(-r,r);
y = zeros(size(x));
for i = 1:length(x)
y(i) = H;
else
end
end
end
y2 = linspace(0,H);
wmin = - wplus;
hold on
hold off
Thank you!
  • #31
Now your talking about the projection of a cylinder into a plane, I believe. The projection would have two parallel sides corresponding to the sides of the cylinder with elliptical end caps. (Whether a projection or a slice at some non-zero angle, you don't get a trapezoid.)
Does the flux pass through the entire cylinder?
Likes magnetpedro
  • #32
Yes, it does!
  • #33
Then, I guess you are asking about a projection, which is a long rectangle with the short ends replaced by half an ellipse. If you have a small light source across the room, it's the shadow cast by a soup can near the wall.
