AS-level SUVAT / Newtonian physics-based question
  • Thread starter Thread starter DJsTeLF
    Newtonian Suvat
The discussion revolves around calculating the average total upward force acting on a diver who enters the water at 7.92 m/s and comes to rest 1.6 meters below the surface. The diver's mass is 72 kg, leading to a calculated decelerating force of approximately 1411 N. However, the model answer indicates that the total average upward force is 2117 N, which includes an additional 706 N to counteract the diver's weight due to gravity. This additional force is necessary for the diver to come to a complete stop, highlighting the importance of considering both kinetic energy and gravitational potential energy in the calculations. The discussion emphasizes that understanding buoyancy is not essential to solve the problem, as the upward force must simply exceed the downward gravitational force.
DJsTeLF
Diver enters the water at 7.92 [ms][/-1] and comes to rest 1.6m below the surface.
Calculate the average total upward force acting on the diver which brings his verticle velocity to zero.
From an earlier part of the questions the divers mass is 72kg.
Thus far I have solved this by equating the verticle kinetic engery of the diver on entering the water with the work done by the water in decelerating him to a stop.
The answer I get is [average decelerating force]\approx[/1411N]
The model answer however states that the total average upward force is 1411 + 706 = 2117N.
My question is therefore from where do they / should I get the other 706N from?
\Delta[/\frac{1}{2}m[v][/2]] = decelerating force x 1.6m<br /> <br /> Decelerating force = 0.5 x 72 x [7.92][/2] / 1.6 = 1411N
It's weighty problem.
Is this meant to be a joke or a hint at the solution?
It did make me consider whether they expect the student to realize that to come to rest the diver would have to be neutrally bouyant in order to properly come to rest under water.
Downward force due to gravity = mass x gravity = 72 x 9.8 = 705.6N
Therefore equivalent upward force would be necessary for diver to come to a stop.
It appears I've found a route to the answer but this seems like a hell-of-an insight for a 16yr old student to have without any 'nudges' towards considering neutral bouyancy in the question??
Comments welcome
You don't need the details about buoyancy to solve the problem. All you need to know is that the work done to bring him to a halt has to take into account the change in potential energy due to gravity as well as the kinetic energy he needs to lose. Hence the hint about gravity (okay, it was a joke, too). The result is that there's an extra force acting upward (you don't care about the source) to counteract the downward force due to his weight.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
