Ask in Experiment Resolution of Vectors
The discussion focuses on the addition and resolution of vectors, comparing graphical and analytical methods for accuracy. It highlights that while graphical methods provide a visual representation, analytical methods, such as component addition, yield more precise results. Possible sources of error include misalignment in graphical methods and measurement inaccuracies in analytical methods. The necessity of allowing strings to slip loosely around the ring is emphasized to minimize frictional forces that could affect the results.
  • Understanding of vector addition and resolution techniques
  • Familiarity with graphical representation of vectors
  • Knowledge of analytical methods for vector components
  • Basic principles of experimental physics, including error analysis
  • Research the differences between graphical and analytical vector addition methods
  • Study sources of error in experimental physics
  • Learn about the impact of mass and friction in vector resolution experiments
  • Explore the role of gravitational acceleration in vector calculations
Students and educators in physics, particularly those focusing on vector analysis and experimental methodology in physics labs.
happyful
can you help me in my
Experiment
Addition and Resolution of Vectors
Questions
1-
Compare the graphical and analytical (addition of components) methods for adding vectors.
Which is more accurate? Give possible sources of error for both methods. Why is it useful to use both methods?
What are the possible sources of error in the experimental method? (Why is it necessary to allow the strings to slip loosely about the ring**
If the weights of all the mass hangers were the same, could their weights have been neglected? Explain.***
What is the effect of the weight of the ring? What difference would it make if the ring were considerably more massive****
do the thoritcal value of m3 and @3= angle 3 depend upon accelaration due to gravity g
thank you very mush
sara
Welcome to PF!
Hi sara! Welcome to PF! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
thank you tiny yes i am stuk :(
i nee for you help
how i can answer thi question
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 22 ·
