[Astrophysics] Star luminosity-radius-temperature problem
  • Thread starter Thread starter Andrev
    Astrophysics Star
The discussion centers on solving a homework problem related to the luminosity-radius-temperature relationship of a Cepheid variable star. The initial confusion arises from the use of logarithmic equations versus direct calculations of luminosity ratios. The participant initially questions why logarithmic methods are necessary, as they seem to yield different results from direct calculations. Ultimately, they resolve the issue by recognizing the inverse nature of the magnitude scale, which clarifies their calculations. The problem is successfully solved using both approaches.
Andrev
Hi!
The light variation of a Cepheid is 2 mag,if its effective temperature at maximum luminosity is
6000K, while at minimum is 5000K, please estimate the ratio of its maximum and minimum
radius.
$$\Delta m=-2,5lg\frac{L_{min}}{L_{max}}$$
$$lg\frac{L_{min}}{L_{max}}=2lg\frac{R_{min}}{R_{max}}+4lg\frac{L_{min}}{L_{max}}$$
Well, actually I should solve the problem with those two formulas above. My question is: why I can not just calculate the $$\frac{L_{min}}{L_{max}}$$ and solve the $$\frac{L_{min}}{L_{max}}=\frac{4\pi R_{min}^2 \cdot T_{min}^4\cdot \sigma}{4\pi R_{max}^2 \cdot T_{max}^4\cdot \sigma}$$ equation? Why I have to calculate with the lgs? As I studied the problem it looked for me that these two methods are equal but I got different results.
Thanks in advance,
Andrev
Sorry for spamming the forum with this I solved it on my own:
Of course I can calculate with the form without lgs too. I missed the calculation at the beginning: I forgot that the magnitude scale is inverse, so $$-0.4\cdot (m_1-m_2)=-0.4 \cdot \Delta m <0$$ It is ok now. Andrev
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
