Solving Asymptote Trouble on Scatter Plot: Regression or Line Fit?
  • Thread starter Thread starter CestLaVie9009
    Asymptote
The discussion focuses on fitting a scatter plot with an appropriate regression or line. A suggested equation, y=3/((x-3.75)/2.75)+9, is noted as a good fit. To eliminate the unwanted curve left of the asymptote, adjusting the minimum x-value to x_low = 3 is recommended. Additionally, improving the fit can be achieved using Excel with the Solver add-in. Overall, participants emphasize the importance of adjusting the x-range and refining the equation for better results.
CestLaVie9009
scatter plot needs a regression? or line best fitting it.
so far y=3/((x-3.75)/2.75)+9 is a pretty good fit
graph is attached
any suggestions on how to get rid of everything left of the asymptote?
Hello, I do not know how your calculator works. But if you set the minimum value of x so that the bottom left curve won't be displayed, it should work. Or are you looking for another equation to fit your data?
A few comments:
The 3 and 2.75 in your equation can be combined into a single number.
As kazumi said, changing the range of x-values should get rid of the unwanted curve. Looks like x_low = 3 should work here.
If you're looking to improve the fit, it can be done in Excel. You would need to have the Solver add-in installed.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
