How Do You Calculate Thermodynamic Properties for Heated Water?
To calculate thermodynamic properties for heated water, start with the known values: density at 298K is 0.9970 g/cm³, and the heat capacity is 75.3 J/K mol. The change in volume with temperature can be determined using the coefficient of thermal expansion, ß = 2.07 x 10^-4 K^-1, and the formula dV = V(initial)ßdT. The heat transfer can be calculated using q = mcΔT, while the work done during expansion is found using PΔV. Finally, apply the relationships dU = q + w and dH = qp to find the changes in internal energy and enthalpy.
thechamp
At 298K and 1 bar pressure, the density of water is 0.9970g/cm3, and Cp,m = 75.3 J/K moL. The change in volume with temperature is given by dV=V(initial)ßdT where ß, the coefficient of thermal expansion is 2.07*10^-4 K^-1 . If the temperature of 250 g of water is increased by 38.0K, calculate w,q,dH,dU
dV=V(initial)ßdT
dH = qp (heat at constant P) = u + w = u + PV
dU= q + w
The answer should be w=-0.197J, q=39700J, dH=39700J, dU= 39700J but I have no idea how to solve this problem. I don't even know where to start...I am completely lost. Please help
The unit conversions are a little annoying, but the problem is straightforward for the most part. Use the standard Chem 101 formula for heat ##q=mc\Delta T##
Calculate the change in volume and use that to find the expansion work ##P\Delta V## (make sure to get the sign right!). Then you can use these quantities to get ##\Delta U## and ##\Delta H##.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
