At what distance has spheres decreased Electric potential by 700V?
A metal sphere with a radius of 15 cm and a net charge of 2.0E-8C has an electric potential at its surface calculated to be 1198.9V. The problem involves determining the distance from the sphere's surface where the electric potential decreases by 700V, resulting in a potential of 498.9V at that point. Attempts to solve for the distance using the formula r = kQ/Vsurface led to incorrect results, with calculations yielding distances of 0.2569m and 0.584m. The correct approach involves using the formula r = kQ/V to find the distance from the center, which must then be adjusted to find the distance from the surface. The final calculation suggests a distance of 0.361m from the center, indicating a need to subtract the sphere's radius to find the distance from the surface.
mr_coffee
Hello everyone, I managed to get Parts (a) and (b) of this problem but can't get the last for some reason. A metal sphere of radius 15cm has a net charge of 2.0E-8C. THe question is, at what distance from the sphere's surface has the electric potential decrased by 700V? Well i found the electric field to be 7992.7 N/C at the sphere's surface. I also found If V = 0 at infinity, what is the electric potenital at the sphere's surface? I used Vsurface = kQ/(r). to find Vsurface being equal to 1198.9V. But I can't figure this part out. I pluged in 700V for Vsurface and solved for r, and got .2569m. r = kQ/Vsurface; This was wrong So i tried, Vf - Vi = -\int E.ds Plugged 700V for Vf-Vi and solved for ds, because i know E from above and I know Vf-Vi, and i got .584m, also wrong any ideas? thanks
You know the potential at the surface from V = k Q /r. What's the potential at the point of interest? It's 1198.9V - 700V= 498.9V. Plug that into the formula and solve for the new distance.
hm...that looked like it would work perfectly but its still wrong for some reason... I got .361m, r = [(9.0E9)(2.0E-8)]/(498.9)
That's the distance from the center; what they want is the distance from the surface.
