zuz
- 99
- 36
Why don't other large moons in our solar system have atmospheres like Titan?
what research have you done on this? What have you found so far?zuz said:Why don't other large moons in our solar system have atmospheres like Titan?
This would then depend on a combination of gravity and (local) surface temperature.DaveC426913 said:Below a certain size, most minor moon will have virtually no atmo simply because they lack the gravity to hang into it.
I agree it's unlikely but given how reactive oxygen is, that isn't necessarily true. It could be a modest amount that is reacting to something.Filip Larsen said:but since it gravitationally could retain some oxygen it then must mean that over time there has been no significant gaseous oxygen producing process on Titan.
True, I should probably have said net production of oxygen.phinds said:I agree it's unlikely but given how reactive oxygen is, that isn't necessarily true. It could be a modest amount that is reacting to something.
Thanks, That helps explain a lot.Filip Larsen said:Regarding comparing escape speed and surface temperature for various gasses I found this nice diagram:
https://en.wikipedia.org/wiki/Atmosphere#Compositions
(Click diagram for big version)
Note that color bands indicate what kind of gas the planet or moon in question can expect to gravitationally hold on to and not that the gas necessarily is present. For example, Titan has no atmospheric oxygen (it has 94% nitrogen), but since it gravitationally could retain some oxygen it then must mean that over time there has been no significant gaseous oxygen producing process on Titan.
Also, the sharp edges of the color bands in the diagram does not indicate there is a sharp limit where on one side the gas can be fully retained and on the other it all escape, but as mentioned earlier, it more indicates that as you go down or to the right on the graph the rate of loss for that particular gas increase. So well below the color band of a gas, only trace amounts of the gas should be expected to be present (if at all).
