Atmospheric pressure in the higher tank
In the discussion about atmospheric pressure and water flow between two tanks, the primary focus is on how atmospheric pressure influences water movement. It is noted that atmospheric pressure in the lower tank can push water up into the higher tank, but questions arise regarding what causes the water in the supply tube of the higher tank to descend. The role of gravitational potential energy is highlighted, suggesting that water naturally moves from higher to lower elevations. Participants express a desire for both simple and complex explanations of these dynamics. Ultimately, the conversation emphasizes the interplay of atmospheric pressure and gravitational forces in fluid movement.
Idea04
If you had a tube running from the top of one tank at a lower level to the top of another tank at a higher level.
And the water could only flow in one direction towards the higher tank.
And the water level in the high tank started to descend.
I think the tube would pull water up because of atmospheric pressure on the low tank pushing the water up.
But what makes the water in the supply tube of the higher level tank descend?
Wouldn't the atmospheric pressure in the higher tank transfer its pressure to the water in the tube. So the water in the supply tube is 14.7psi. the same pressure as the surface of the water in the tank.
Or does gravitational potential energy play a factor
What is the difference in the atmospheric pressure at the lower tank compared to that at the upper tank?
I just thought that there would be other forces involved in forcing the fluid to move.
I'm not saying that the only thing to consider is the atmospheric pressure. You brought it up, so I figured at least we could calculate the difference to see how significant that effect might be...
Okay but if you have water in the supply tube at a higher level than the tank wouldn't the water want to move from higher elevation to lower elevation.
This question is tricky depending on the details.
The water should like to lower its P.E., yes.
So would the need for the water to lower it P.E., would that allow the water to flow.
Uncomplicated answer-yes.
can you give me the complicated answer so I can understand it properly
lol. What level class is this question from?
Last question.
Does the descending water in the tank give energy to the water in the supply tube.
