How long is the bus trip from Balamb to Galbadia?
The bus trip from Balamb to Galbadia typically takes about 18 minutes at an average speed of 70 km/hr. On days with heavy traffic, the speed decreases to 40 km/hr, resulting in a longer travel time. To determine how much longer the trip takes under these conditions, calculating the distance of the trip is essential. The discussion emphasizes the importance of showing previous attempts at solving the problem for better assistance. Accurate calculations will clarify the impact of traffic on travel time.
HiSoCReeD
On certain days, traveling to Balamb from Galbadia using a bus takes an average speed of 70 km/hr. The trip takes about 18 minutes. On a busy traffic day, the drive slows down to 40 km/hr over the same distance. How much longer does the trip takes?
Thanks
Welcome to PF HiSoCReeD.
Unfortunately you have completely deleted the "attempt at the solution" section from your new post so we can't see what you have already tried.
To get you started: it may help to first calculate the distance of the bus trip.
