Average velocity problem~From Jay Orear book.
The discussion revolves around calculating average velocity when a car travels two distances, x1 and x2, at velocities v1 and v2, respectively. The average velocity should be weighted by the distances traveled, meaning longer distances contribute more to the average. The correct formula involves multiplying each velocity by its corresponding distance, summing these products, and dividing by the total distance. Participants clarify that "weighting factors" refer to the distances traveled at each velocity, which is crucial for this calculation. The problem is sourced from Jay Orear's book, highlighting the distinction between average velocity by time and average velocity by distance.
Biggy_G
Car passes distance x1 with velocity v1
further it passes distance x2 with velocity v2. Find average velocity (averaged by distance), at that consider x1 and x2 as weighting factors.
Vaverage=(v1t1+v2t2)/(t1+t2)
I used substitution t=x/v and replaced t's in the formula and tried to simplify, but couldn't get correct answer.
I will be grateful for anyone's help.
Thanks
What do you mean by weighting factors?
Other than that averge vel=(v1*t1+v2*t2)/t1+t2 doesn't seem wrong from any angle...
Thanks
If they want the velocity averaged by distance, then the distances become the weighting factors (so that more "weight" is given to longer distance stretches in the figuring of an average). Multiply each velocity by its "weighting factor" (which is the distance that it traveled at that speed), sum them up, and divide by the sum of the weights.
Frankly Gneill i did not exactly get you...
I have done some physics but have never come across this term "weighing factors" and i always thought that average velocity is always total displacement by total time...
Ok i will search this term up in google and then i will try and get back to you...
Thanks gentlemen for replies,
The thing is I found this problem in Jay Orear's book. Chapter 2 Excercise 5. I am reading the book in Russian and I think that I translated Weighting Factor correctly. When they say Average velocity, mostly authors mean Velocity averaged by time. However, as they say, weighted by distance average velocity is used in Hydrodynamics.
Exactly Correct answer :) Thanks
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
