[b]1. The problem statement, all variables and given/known
  • Thread starter Thread starter Joe91090
    Variables
The discussion revolves around calculating the single displacement required for an expert golfer to sink a ball in one stroke after a novice golfer takes three strokes. Participants clarify the use of vector components, specifically addressing the northeast direction as 45 degrees. The method involves breaking down each putt into its x and y components and then summing these to find the resultant displacement. One user successfully computes the correct displacement after receiving guidance on the vector components. The conversation emphasizes the importance of accurate vector representation and calculation in solving the problem.
Joe91090
A novice golfer on the green takes three strokes to sink the ball. The successive displacements are 1.6m to the north, 7.4m northeast, and 3.7m 57 degrees west of south. starting from the same initial postion, an expert golfer could make the hole in a single displacement. What is the magnitude of this single displacement ?
SOH CAH TOA
IM confused if northeast is enough information to solve the problem. I used SOH CAH TOA to find the lengths of the sides of the triangle and put northeast as 45 degrees but I am not sure if that correct. I subtracted the vectors and used the pathagreon theroum to find the displacement but my answer can out inncorrect.
SOH CAH TOA
Maybe try a more careful method?
Putt-1 = 0 i + 1.6 j
Putt-2 = ... i + ... j
Putt-3 = ... i + ... j
Then add your components and use Pythagoras?
(And yes, northeast is 45°)
What do the i and j represent ?
Those are the x and y components of the vector.
It went 1.6 north and 0 in the east-west direction.
So... displacement is 2.1 i + 4.8 j ??
Putt 1: 0 i + 1.6 j
Putt 2: 5.2 i + 5.2 j
putt 3: 3.1 i + 2 j
That's the idea.
Looks right, though the signs on Putt-3 aren't exactly right. The result is apparently.
I GOT IT RIGHT ! thanks for the help
You're welcome of course.
But don't act so surprised.
