Calculating Height of an Apartment House from Dropped and Thrown Balloon Data
  • Thread starter Thread starter Michael805
    Ball
The discussion revolves around calculating the height of an apartment building based on the motion of two balloons dropped and thrown from the roof. One balloon is dropped from rest, while the other is thrown downward 2.7 seconds later with an initial speed of 52.92 m/s, and both hit the ground simultaneously. The initial calculations suggest the building is 31.36 meters tall, but this is identified as incorrect due to a misunderstanding of kinematic equations. Participants emphasize the need to use the appropriate kinematic formula to relate displacement, time, and initial velocity for accurate results. Clarification on the correct approach to solving the problem is sought to resolve the confusion.
Michael805
You and your friend are on top of a roof... You simply drop a balloon from rest. Your friend throws a balloon downward 2.7s later with an initial speed of 52.92m/s. They hit the ground at the same time. Neglect air resistance. How high is the apartment house?
2. The attempt at a solution
My thinking on this is that after 3.2 seconds balloon 1 has traveled 31.36m, and balloon 2 has traveled 31.36m after .5 seconds, meaning the building would be 31.36m tall, but evidently my thinking is off somewhere.
So, if anyone could explain what it is I'm doing wrong with this one, it would be much appreciated.
Thanks.
Hi Michael805,
I don't believe this is correct. How did you find this result?
(It appears that you multiplied 9.8 times 3.2, which would give the speed of ball 1 right at t=3.2 seconds, since it has no initial velocity.)
You do want to find an expression for the displacement (which would be \Delta x or \Delta y in the equation); so what kinematic equation would relate displacement, time, and the quantities they give you in the problem?
what formula did you use to get to that answer?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
