Ball thrown vertically in air question?
  • Thread starter Thread starter yamaha277
    Air Ball
The discussion revolves around solving two physics problems involving a ball thrown vertically. For part a, the maximum height reached by the ball is calculated to be 5.10 m, and the height when the velocity is 5.0 m/s is determined to be 3.83 m using the equation v^2 = u^2 + 2as. In part b, given the height of 6.07 m at a velocity of 5.0 m/s, the initial velocity is calculated to be approximately 11.99 m/s. The participants emphasize the importance of understanding the equations of motion to solve these types of problems effectively. The final calculations for both parts are confirmed as correct.
yamaha277
a) A 2.0 kg ball is thrown vertically in the air with an inital velocity of 10.0 m/s. What is the height of the ball when the velocity is 5.0 m/s?
b) A 2.0 kg ball is thrown vertically in the air. The height of the ball when the velocity is 5.0 m/s is 6.07 m. What is the initial velocity of the ball?
the max height reached by a) is 5.10 m
I know how to find the max height reached by the ball with the initial velocity but can't figure out how to find the height at certain velocities.
Please help!
Do you know "v^2 = u^2 + 2as" ?
This?
(square of final velocity) = (square of initial velocity) + 2*acceleration* distance
Would your final velocity in a) be 5.0 m/s therefore solving for s?
If that is correct, i get 3.83 m
There are three standard equations of motion (see the sticky at the top of this thread)
You need to know them - and which to use depending which factors you know.
I have those and got:
A) 3.83 m
B) 11.99 m/s
Does the seem right?
