Ballistics pendulum - sort of - COM
A physics problem involves a bullet passing through a wooden block, prompting questions about kinetic friction, energy loss, and the block's kinetic energy post-collision. The calculated coefficient of kinetic friction is approximately 0.222, the decrease in kinetic energy of the bullet is around 291.2 J, and the block's kinetic energy immediately after the bullet exits is about 0.784 J. The calculations were verified by peers, suggesting they are correct. The discussion highlights the importance of precision in physics problems.
pat666
A 4.00-g bullet, traveling horizontally with a velocity of magnitude 400 m/s, is fired into
a wooden block with mass 0.800 kg, initially at rest on a level surface. The bullet passes
through the block and emerges with its speed reduced to 120 m/s. The block slides a
distance of 45.0 cm along the surface from its initial position.
(i) What is the coefficient of kinetic friction between block and surface?
(ii) What is the decrease in kinetic energy of the bullet?
(iii)What is the kinetic energy of the block at the instant after the bullet passes through it?
We have a physics exam coming up and they gave us a couple of practice questions with no answers. I solved these but I am unsure if there correct can someone please take a look. thanks
i) 0.221996
ii) 291.2J
iii) 0.784J - i actually found this one while solving i) i used W=Fs i think you can use kinematics for acceleration and the use F=ma
'Got a little crazy with the precision in i), huh? :-p But seriously though, the answers look ok to me. :approve:
yeah i guess i did. thanks
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
