Bandpass Filter Homework Statement
The discussion revolves around the design and analysis of a bandpass filter constructed using an RC highpass filter followed by an RC lowpass filter. The problem involves determining the appropriate capacitor values for specified cutoff frequencies in the audio range and analyzing the gain at a particular frequency.
  • Mixed
  • Participants explore the calculation of capacitance values based on given resistor values and cutoff frequencies. There is discussion on the appropriateness of the gain formula used for the lowpass filter and whether the calculations align with the expected results.
Some participants have confirmed the capacitor values as reasonable, while others question the formula used for gain, seeking clarification on its application. There is a recognition of the need to verify calculations, and adjustments to initial results have been made.
Participants are working under the constraints of specific cutoff frequencies for vocal audio and are considering the implications of isolating the lowpass filter's contribution to the overall gain.
Lucille
A simple way to build a bandpass filter is to filter the output of an RC highpass filter with an RC lowpass filter, as shown on the left in the diagram below. The isolation buffer is a circuit element that keeps the two circuits isolated so they behave as they would on their own. The (highly idealized) response of the circuit is shown on the right, where fL and fH are the low and high cutoff frequencies.
a) Assume fL is given by the equation for the cutoff frequency of a high pass filter, and fH is given by the equation for the cutoff frequency of a low pass filter. If the value of the resistors is 10 kOhm what should the value of the capacitors be if you were building an audio filter to allow vocal frequencies between fL = 80 Hz and fH = 1100Hz.
b) Assuming the high frequency behavior of the filter is described entirely by the response of the low pass filter, what would the gain, Vout/Vin, be at 10 000 Hz?
Image available at http://www.chegg.com/homework-help/questions-and-answers/simple-way-build-bandpass-filter-filter-output-rc-highpass-filter-rc-lowpass-filter-shown--q3608656
f_c = 1/(RC*2Pi)
Vout/Vin = 1/ sqrt(1+(RwC)^2)
a) C = 1/(2pi*f*R) -- do I calculate two different capacitance values?
so C1 = 1.99*10^-7 and C2 = 1.45*10^-8
b) Using C2 and plugging into the equation gives 0.568
Your capacitor values look fine.
I'm not sure about the formula you've used for the gain. What particular setup is it for? The question specifies that you consider only the low pass filter portion's contribution.
It is for a low pass filter -- and so I used the value for C = 1.45 * 10^-8 F and subbed it into the equation for the gain of a low pass filter
Okay, that would be correct, but the result you've obtained looks a bit high to me. Can you check you math?
Whoops - I got 0.109
Much better :smile:
Thank you so so so much! It makes so much more sense to me now.
  • · Replies 27 ·
