What Steps Can Solve the Frictional Force in a Banked Curve Problem?
The discussion focuses on solving a physics problem involving a car navigating a banked curve, where the frictional force needs to be determined. The user has correctly set up free body diagrams and equations for the net forces in both the x and y directions but is struggling with the calculations. Suggestions include resolving the frictional force into its components and ensuring the correct application of trigonometric functions. The final calculations yield a normal force of 13972.5 N and a frictional force of 2257.5 N acting down the incline, which is consistent with the conditions of the problem. The derived coefficient of friction is 0.161, indicating a feasible solution.
HeatherH
I've been working on this problem for hours and I just can't figure out what to do next! Here it is-
A car drives around a curve with radius 410 m at a speed of 32 m/s. The road is banked at 5.0 degrees. The mass of the car is 1400 kg. What is the frictional force on the car?
I drew the FBD and got net force equations for the x and y directions:
Fxnet: Fsin(theta) = m(vsquared)/r -Nsin(theta)
Fynet: Fcos(theta) = Ncos(theta) - mg
But now I don't know what to do. I know what the correct answer is (back of the book), but I can't figure out how to get there. When I plug in the numbers, it doesn't come out right. Are my net force equations wrong?
Hints? Suggestions? Please!
Thanks, Heather
What about the frictional force f? Resolve it into horizontal and vertical components and add it to your equations of motion.
The frictional force is the Fsin(theta) for the x/horizontal and Fcos(theta) for the y/vertical. I think I did that part right, but I'm really not that great at physics, so it could be wrong.
ok I am defining x to be radially inwards/outwars and the y direction to be up and down. These directions are as I stated them and not oriented along the incline. It seems in your equations you had the wrong trig function associated with the friction and some of your directions were opposite.
From the FBD in the Y direction we have
Normal*cos(theta) + Friction*sin(theta) - Weight = 0
From the FBD in the X direction we have
Normal*sin(theta) - Friction*cos(theta) = m*v^2/r
2eqns, 2 unknowns (Normal and Friction), the system is linear too!
Sorry I really don't feel like solving this algebraiclly so I am just going to throw in the numbers
This gives
Normal = 13972.5 N (perpendicularily outwards of the incline)
Friction = -2257.5 N (up the incline)
Notice in the model I chose I had friction acting up the incline, because this value is negative, we know the actual frictional force is
Friction = 2257.5 N (down the incline)
This is feasible as Friction < Normal
These values give u = 0.161 which is a reasonable value for the coefficient of friction
