Banking angle and curvature radius of an airplane
To determine the minimum curvature radius for a plane flying at 950 km/h with a maximum banking angle of 40 degrees, the relevant equation is F = mv²/r. The banking angle affects the lift and centripetal force required for the turn. Assuming the lift force remains constant when banking, the angle plays a crucial role in calculating the necessary radius. The relationship between speed, banking angle, and radius must be analyzed to find the solution. Understanding these dynamics is essential for solving the problem effectively.
lu22
If a plane is flying level at 950 km/h and the banking angle is not to exceed 40 degrees what is the minimum curvature radius for the turn?
possibly F = ma = mv2 / r ?
no idea where to start on this one, not sure where the angle factors into everything
Assume that the force of the air on the plane in the direction perpendicular to the wings does not change when the airplane banks.
AM
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
