What Happens When Ba(NO3)2 Reacts with NaOH?
  • Thread starter Thread starter tobyguy
    Formula
The reaction between barium nitrate (Ba(NO3)2) and sodium hydroxide (NaOH) is a double displacement reaction, resulting in the formation of sodium nitrate (NaNO3) and barium hydroxide (Ba(OH)2). The balanced chemical equation is Ba(NO3)2 + 2NaOH → 2NaNO3 + Ba(OH)2. It is noted that barium has a valence of 2, which means two hydroxide ions are needed to form barium hydroxide. A correction was made regarding the initial reaction formula provided, emphasizing the importance of proper balancing. The discussion highlights the significance of understanding valences in chemical reactions.
tobyguy
If you mix BaNO(3)2 + NaOH what would be the chemical chemical reaction in formula?
a simple double displacement reaction
Ba (NO_{3})_{2} + 2Na OH \rightarrow 2NaNO_{3} + Ba (OH)_{2}
balance away!
p.s. dexter is right since Ba has 2 valences there will be 2 OH ions in barium hydroxide
Thanks that really helped. :-p
The reaction provided is incorrect.
Ba\left(NO_{3}\right)_{2}+NaOH\rightarrow NaNO_{3}+Ba(OH)_{2}\downarrow
Do you see the difference?
Daniel.
