Calculating the Mass of a Negative Ion with a Specific Charge
  • Thread starter Thread starter ManchesterDan
    Physics
The discussion centers on calculating the mass of a negative ion with a specific charge of 1.20x10^7 C kg^-1 and a negative charge of 3.2x10^-19 C. Participants question whether the term "negative charge" is misleading, as it could imply a negative mass if interpreted literally. Clarification is provided that the negative charge refers to the ion's charge, not its mass, which remains a positive value. The calculated mass of the ion is confirmed as 2.67x10^-26 kg, consistent with the charge being twice that of an electron, suggesting it is an oxygen ion. The conversation highlights the importance of precise language in scientific discussions.
ManchesterDan
Calculate the mass of an ion that has a specific charge of 1.20x10^7 C kg^-1 and a negative charge of 3.2x10^-19 C.
Textbook answer: 2.67x10^-26 kg.
Question: if the ion has a negative charge of 3.2x10^-19, isn't that -3.2x10^-19?! In which case the answer would be -2.67x10^-26 kg?! Is the use of the word negative in this question a bit misleading?
Hello Dan.West Ham supporter here(don't take the mickey).You make an interesting point.Specific charge is a ratio and I don't recall having seen it given either a positive or negative label.Thinking about it,it might seem to be more instructive to do so.
Hi Dadface, it isn't actually the specific charge I'm concerned about, its the charge of the ion. Is 'a negative charge of 3.2x10^-19 C' the same as -3.2x10^-19 C?! In which case the answer would be -2.67x10^-26 kg?! Is the use of the word negative in this question just a bit misleading?
Thanks very much!
P.s. Just watching the Bolton game myself!
Yes it is the same and it is twice the charge of the electron.From its charge and mass it looks like it's an oxygen ion.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
