How do I calculate the force applied to a tennis ball when it is hit by Pete?
  • Thread starter Thread starter jrbillbrian
    Forces
To calculate the force applied to a tennis ball by Pete, the mass of the ball is 54 grams (0.054 kg) and it is served at a speed of 53.6 m/s over a distance of 49.7 cm (0.497 m). The initial velocity is assumed to be 0 m/s, allowing for the use of the equation Vf^2 = Vi^2 + 2a * Δx to find acceleration. After solving for acceleration, the force can be calculated using F = ma, resulting in a force of 156 Newtons. The discussion highlights the importance of correctly converting units and applying the right equations to arrive at the solution.
jrbillbrian
Pete serves a tennis ball of mass 54 grams at a speed of 53.6 meters per second. The ball is in contact with Pete's racket through a distance of 49.7 centimeters. What force does Pete apply to the ball?
54 grams = 0.054 kg
Speed = 53.6 m/s
49.7 cm = 0.0497 m
Force = mass x acceleration
Vfinal = at + vi
I am VERY lost, considering the fact that our teacher told us to try and figure it any way we could.
I tried this. 0.0497 m = 0.5(53.6 m/s) * t2
t = 0.0420183500 s
Then I thought of the statement
It takes 0.0420183500 seconds to travel 0.0497 m when traveling at 53.6 m/s
Then I tried Vfinal = a*t + Vinitial
56.3 m/s = a * 0.0420183500 s
a = 1339.890784 m/s2
Force = 0.054 kg * 1339.890784 m/s/s
Force = 72.4 N
Can anyone help me out with this please?
Since you are given the distance over which the force was applied, you should probably use an equation that has distance.
The way I read this question, you are given the following:
\Deltax = .497m
vi = 0 (<-- not given, but I'm assuming the ball wasn't moving until he hit it)
vf = 53.6 m/s
You are trying to find acceleration.
Find an equation that has \Deltax, vi, vf, and a in it, and solve for a.
Once you find acceleration, you can use the F = ma equation to find the force.
Does this make sense?
Yes, what you are suggesting seems to make sense. I will try it and let you know if I figure it out. Thanks
Thanks! I got it. One major and obvious problem that I discovered was the fact that I converted it to 0.0497 m rather than 0.497. I ended up using Vf^2 = Vi^2 + 2a * delta x
I solved for 156 Newtons. Thanks
That's the same answer I got too. Good job! Glad to help!
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
