How can Pete solve a logarithmic problem using the Change of Base Formula?
  • Thread starter Thread starter Helicobacter
    Logarithmic
To solve the logarithmic problem using the Change of Base Formula, Pete can start by recognizing that x^(log base x of y) simplifies directly to y. This follows from the definition of logarithms, where log_x(y) indicates the exponent to which x must be raised to yield y. By applying the property that x raised to the logarithm base x of y equals y, Pete can confidently conclude that x^(log_x(y)) = y. Understanding this relationship eliminates confusion about the cancel-out rule in logarithmic expressions. Thus, Pete can effectively solve the problem using his knowledge of logarithmic definitions and properties.
Helicobacter
Pete has access to a scientific calculator and only knows the Definition of a Logarithm and the Change of Base Formula. How is Pete able to solve the following problem?:
x^(log base x of y) =
Mathematics news on Phys.org
What is the definition of a logarithm ?
log base b of n = x <=> b^x = n
Let
\xi = \log_x y
\Leftrightarrow x ^ {\xi} = y, right?
So:
x ^ {\log_x y} = x ^ {\xi} = ?
Can you go from here? :)
Thanks! (Previously I knew the cancel-out-rule, but I didn't understand why you can cancel.)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
13K
