lolphysics3
- 9
How much heat is released freezing 75 grams of steam at 110 degrees celcius into ice at -5.1 degree celcius
Certainly not equal to zero - equal to the heat released that you are trying to find.(Mice*Sice+change in temp ice)=0?
Heat is the transfer of energy from one object to another due to a difference in temperature.
The temperature of an object will increase when heat is added and decrease when heat is removed.
The formula for calculating heat change is Q = mcΔT, where Q is the amount of heat transferred, m is the mass of the object, c is the specific heat capacity, and ΔT is the change in temperature.
Heat is a form of energy, while temperature is a measure of the average kinetic energy of the particles in a substance. Heat can cause a change in temperature, but they are not the same thing.
The specific heat capacity is the amount of heat required to raise the temperature of 1 gram of a substance by 1 degree Celsius. A substance with a higher specific heat capacity will require more heat to raise its temperature compared to a substance with a lower specific heat capacity.
