Time Dilation: Can You Chase Something Too Fast?
i.h87
Forgive me if this has already been asked as I'm trying to understand this, but I can't seem to find the right info..
Basically, what I want to know is if it is possible to chase something so fast that you won't catch it due to time dilation. If an object is traveling at a low sublight speed and another object is following the same path at a near light speed can time dilation make it so that the faster object never catches up to the slower object, or is this nullified because traveling on the same path gives them the same frame of reference?
No. As long as both objects are traveling at less than the speed of light, the faster object will always catch up to the slower one eventually.
I'm not sure what you mean by this, but the reason the faster object will catch up is that, if you look at things in the frame in which that object is at rest, the slower object is moving *towards* the faster object in that frame.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
