Basics of Fluid Mechanics and Pressure
The discussion focuses on understanding the forces acting on a liquid molecule at the surface of a liquid in a container. Key points include the roles of atmospheric pressure, pressure from the surrounding liquid, and the weight of the liquid molecule, with clarification that buoyancy and surface tension also play a role, albeit minimally for small particles. The conversation emphasizes the importance of analyzing fluids at the continuum level rather than the molecular level, leading to the conclusion that pressure calculations should consider a column of liquid rather than individual molecules. Additionally, when a container accelerates, the pressure equation adjusts to account for both gravitational and inertial effects, illustrating the complexity of fluid dynamics. The analysis concludes with insights on how the liquid surface forms an angle due to pressure gradients and the need for equilibrium in fluid behavior.
Tanya Sharma
Hello
I am having difficulty in comprehending the basics of fluid mechanics . I have few questions which I would like to put one at a time , so as not to create any confusion .
In the following attachment , a container with a liquid rests on a surface .I would like to understand what are the forces acting on a liquid molecule(marked in red) at the surface.
1.Atmospheric Pressure P0 acting vertically downwards(Purple)
2.Pressure from the surrounding liquid Psur acting vertically upwards(black)
3.Weight of the particle W acting vertically downwards(green)
Is it correct to say Psur = P0 + W ?
But pressure at the surface due to surrounding liquid Psur should be equal to P0 . Does that mean we neglect W ?
Edit :The red dot represents a liquid molecule at the surface .
Well, you are neglecting two forces here which throw of your simple expression up there: buoyancy (due to the displacement of water by the particle) and surface tension (due to the deflection of the water surface). Depending on the size of the particle, these would likely be small, but so would the pressure from the water.
Ultimately, the gauge pressure from the water would be incredibly tiny for a small particle since only a tiny bit of the particle would dip below the surface and get any kind of pressure on it to support the weight. This is due to the fact that the absolute hydrostatic pressure is p_{\text{atm}} + \rho g h, and in this case the depth of the particle, h, ranges from zero to incredibly tiny.
Okay...that does increase the complexity of the analysis . One thing I want to clear is that by particle I am talking about a liquid molecule at the surface of the liquid .I am sorry if I may have caused some confusion.
Are you sure buoyancy comes into picture when we are analysing forces on a liquid molecule at the surface ? I think it applies only to external object submerged in water .
Is the force due to surface tension acting vertically downwards ?
Again,I am talking about a liquid molecule at the surface .
Right
The problem with analysing molecules is that they don't behave as some stationary objects. At the molecular level, there is no pressure to speak of, there are random walk and collisions. No buoyant force either, because it depends on pressure and density, and "density" of a molecule is something that is very tricky to define.
Usually fluid dynamics deals with "parcels" of matter, which are tiny but still contain huge numbers of molecules, and the notions like pressure and density are applicable.
Okay...so if I need to write a force equation then I should consider a column of water of say height 'h' and cross section area 'A' instead of a single liquid molecule . Is it correct ?
Yes, that is how it is typically done. Surface tension, however, will need to be accounted for differently, if you want to do that at all.
Thanks...
Another doubt I have is regarding the pressure at the surface of liquid .
Is there a single pressure acting at the air liquid interface or are there different pressures on either side of the surface(air on top and liquid beneath the surface) ?
If there is surface tension, the pressures must be equal. Whether that is a "single pressure" is not a very meaningful question, because microscopically pressure is really just motion of molecules, and at the interface you will find molecules of both fluids.
If the surface tension is present, there is a pressure difference.
I think you meant "if there is no surface tension" in the first line .
In the attached figure the container is accelerating upwards with acceleration 'a' .
The forces acting on a column of height 'h' and cross section 'A' are
1) Force due to atmospheric pressure P0A acting vertically downwards (purple)
2) Force due to liquid beneath the column PA acting vertically upwards(red)
3) Weight ρhAg acting vertically downwards (pink)
4) pseudo force ρhAa acting vertically downwards (black)
Doing ∑F = 0
P0A+ρhAg+ρhAa = PA
or P = P0+ρh(g+a)
Is this the correct expression for the pressure at a point in the liquid in a container accelerating upwards ?
Things get tricky here, because now air will have dynamic pressure in addition to the static pressure. Ignoring that, your equation is correct.
It follows immediately from Einstein's equivalence principle, by the way.
And if that is a closed container with vacuum at top of liquid then P=ρh(g+a) . Right ?
What does this principle tell us ?
Right.
That acceleration cannot be distinguished from gravitation in small volumes. So if you have "real" gravity ##\vec g## and "real" acceleration ##\vec a##, you cannot really say whether you have "pure" gravity ##\vec g - \vec a##, or "pure" acceleration ##\vec a - \vec g##.
Just a few comments:
1. To elaborate on what Voko said earlier, when you are dealing with concepts like pressure and density, you need to be thinking at the "continuum" level, not the molecular level. Once you do that, all your difficulties will vanish.
2. The analysis you did on the accelerated column was right on target. Nice job. As far as what was said about the added pressure required to push the air above, this is the same kind of thing as worrying about air drag on a solid. Not very important from your current perspective.
3. As far as surface tension is concerned, if the surface is flat, it does not come into play in the force balance perpendicular to the surface. Only if the surface is curved is there a difference in pressure across the interface. The surface tension always acts tangent to the surface.
Hope this helps.
Chet
Likes 1 person
Hi Chet :smile:
Thanks for chipping in .
I would like to discuss the case of accelerating fluid in horizontal direction.
I have attached the figure .
If I set up my coordinate axis with + y-axis upwards and + x-axis towards right .θ is the angle which the liquid surface makes with the horizontal .Then,
PAcosθ-P0Acosθ-ρhAg = 0
PAsinθ-P0Asinθ-ρhAa = 0
Hence,tanθ = a/g
If I set up my coordinate axis with + y-axis upwards perpendicular to the surface and + x-axis downwards towards right .Then,
PA - P0A-ρhAgeff = 0
where geff = g - a and magnitude of geff = √(a2+g2)
Is my analysis correct ?
Yes, your analysis and its result are correct. C.f. #13.
I think this analysis is correct, but it is not the way I would have done it. I'll present the method I would have used, just to provide a different perspective.
At a given time, the pressure is going to be a function of both x and y, so p = p(x,y), and
dp=\frac{\partial p}{∂x}dx+\frac{\partial p}{∂y}dy
I'm going to take a tiny control volume of fluid in the middle of figure with sides Δx and Δy, and width Δz into the paper, and I'm going to do horizontal and vertical force balances on the fluid in the control volume:
[p(x,y)-p(x+Δx,y)]ΔyΔz=ρ(ΔxΔyΔz)a
[p(x,y)-p(x,y+Δy)]ΔyΔz=ρ(ΔxΔyΔz)g
If we divide both sides of this equation by the volume (ΔxΔyΔz) and take the limit as the increments become small, we obtain:
-\frac{∂p}{∂x}=ρa
-\frac{∂p}{∂y}=ρg
The surfaces of constant p are characterized by dp = 0, or
\frac{\partial p}{∂x}dx+\frac{\partial p}{∂y}dy=0
If we substitute the results of the force balance into this equation, we get:
adx+gdy=0
or, equivalently,
\left(\frac{∂y}{∂x}\right)_p=-\frac{a}{g}
Since the free surface is a surface of constant p, this is the slope of the interface.
If we want to find the pressure at a distance h perpendicular to the interface, we take Δx=-hsinθ and Δy=-hcosθ so that:
P=P_0-hsinθ\frac{∂p}{∂x}-hcosθ\frac{∂p}{∂y}=P_0+ρahsinθ+ρghcosθ
But sinθ=\frac{a}{\sqrt{a^2+g^2}} and cosθ=\frac{g}{\sqrt{a^2+g^2}}
So,
P=P_0+ρ\sqrt{a^2+g^2} h
This is the same as your result.
Chet
Excellent analysis...Thank you very much for enhancing my knowledge .
Why does the liquid surface of accelerating fluid forms an angle with the horizontal and becomes perpendicular to geff ?
My thoughts - Because if it weren't perpendicular then there would be a component of geff parallel as well as perpendicular to surface.
There can be no net force perpendicular to the surface (otherwise water would move in that direction and change the surface shape)
There can be no net force parallel to the surface (otherwise layers of water would slip against each other).I think fluids have a no slip condition .But if layers are undergoing same acceleration parallel to surfaces ,why should they slip ?
Not sure . What are Your views ?
Tanya, your reasoning about the orientation of the surface is correct. Liquids can withstand compression, but they cannot resist any shear. So if they can have any stable configuration at all, this is the configuration where the net force is everywhere perpendicular to the surface.
In order to accelerate the fluid to the right, you need a higher pressure on the left than on the right (at a given value of y). So to get the higher pressure on the left, you need more of a fluid column to the left than to the right. That translates into a tilted surface. The pressure gradient vector is perpendicular to surfaces of constant pressure. The interface is one such surface. So the maximum directional pressure derivative is perpendicular to the interface.
The stress vector at the interface must be continuous across the interface. If you do a force balance on a tiny element of area of interface, you can see this right away because the mass involved is zero. The stress on the air side of the interface is P0, and is perpendicular to the interface. There is no component tangent to the interface (shear stress). So, on the fluid side of the interface, the normal stress must be P0 and the shear stress must be zero.
Incidentally, the no-slip boundary condition means that the velocity vector is continuous at an interface (even if the interface is solid). A fluid can be shearing at a stationary solid boundary and still satisfy the no-slip boundary condition (zero velocity, but velocity gradient normal to boundary). In our problem, there is no shearing at the interface because the shear stress imposed by the air is zero.
Likes 1 person
Very Nice...
Does this reasoning go equally good for why pressure at the liquid surface is equal to the atmospheric pressure ?
I have few more doubts
1)How do we say that the pressure at the liquid surface is equal to atmospheric pressure ?
Using P=P0 + gh ,and putting h=0 makes sense . But is there a different qualitative explanation ? If the reasoning you have given above goes with this question also,then it is fine.
2)What exactly is pressure ?
I think of it as Force/Unit Area due to fluid molecules colliding with each other .It only pushes not pulls .Is it correct thinking ?
3)Can we treat liquids just as a rigid body ? Is there a center of mass of the fluid where we can consider all the forces to be acting ?
4)Does Surface Tension act only on curved surface .Does that mean it comes into picture only in case of tubes of small radius containing fluids . In containers with large radius are we neglecting Surface Tension or is it totally absent .
Yes.
The reasoning is the same. The pressure is continuous across the interface, and is equal to the pressure imposed by the air (neglecting surface tension on highly curved surfaces).
Yes.
Not really. Liquids can undergo huge deformations, and forces are transferred between fluid parcels. Not all parts of the fluid are moving identically. Often, we have to look at fluids by considering differential elements.
Surface tension is a property of the fluid, and is independent of the container. It doesn't only act on curved surfaces. But it does always act tangent to the surface. Think of it as an extendable membrane stretched over the surface, separating the gas phase from the liquid phase.
Chet
Likes 1 person
Chet...Thanks for your valuable input.
While studying FLT , work done by an expanding gas is given by pΔV .
My very basic doubts are
1)Is 'p' pressure of the gas or external pressure of the surroundings ?If gas is expanding then surely gas pressure is more than that of the surroundings and vica versa .What is the relationship between the two pressures?
2)There are three things ,gas,container fitted with piston and surroundings .Now ,gas is exerting pressure on the piston i.e doing work on the piston .Piston is doing work on the surroundings. Then why is that it is considered that gas is doing work on the surroundings ? I mean who is doing work on whom ?
3)Is the piston considered in the arrangement always massless or it may have some mass ? How does that affect our results ?
Tanya,
My Blog at my PF personal page may answer many of these questions for you. If not, might I suggest starting a new thread under the heading of first law thermo?
Chet
Okay...I will proceed as per your suggestions.
Thank you very much for your time and patience in explaining the subject matter.
Hello Chet
1) When a container with liquid and having a hole in the side wall is undergoing free fall , the liquid doesn't come out . Is it correct to attribute this to the fact that since there is no hydrostatic pressure in the liquid undergoing free fall the pressure on both sides of the hole will be solely atmospheric . Since there is no pressure difference across the hole the water doen't come out ?Does the reasoning make sense ?
2) Is it correct to say that under free fall ,the pressure througout the liquid is stmospheric pressure ?
Tanya Sharma said:
Hello Chet
Yes.
Yes, aside from sloshing inertial effects.
Chet
Thanks .
Chet ,
A block of wood floats in a bucket of water placed in a lift .If the lift starts accelerating up ,will the block sink more ,sink less or stays at the same level ?
I think the block will sink more as the buoyant force has to increase ( block needs to displace more water) in order to provide net acceleration to the block in upward direction .
Is it correct ?
Tanya Sharma said:
Chet ,
Is it correct ?
What an interesting question! In the accelerating frame of reference of the elevator, what is the pressure of the water as a function of depth?
Chet
  • · Replies 27 ·
  • · Replies 25 ·
