How Does Jumping from a Height Affect the Reading on a Bathroom Scale?
Jumping onto a bathroom scale from a height of 2.0 m affects the reading due to the conversion of gravitational potential energy into spring potential energy. The initial weight reading is 805 N, with the spring compressing 0.50 mm under this weight. At the peak compression, all gravitational potential energy (mgh) is converted into spring potential energy (1/2 kx^2). The correct approach involves setting mgh equal to the energy stored in the spring, rather than using F=kx directly. This discussion highlights the importance of understanding energy transformations in physics.
physicsss
If you stand on a bathroom scale, the spring inside the scale compresses 0.50 mm, and it tells you your weight is 805 N. Now if you jump on the scale from a height of 2.0 m, what does the scale read at its peak?
I used F=kx, and solved for k...but I don't know what to do after that...do I set
mgh=kx, where m is 805/9.8 and h is 2.0m?
The idea is correct.
At the point where the spring is compressed the most, all gravitational potential energy has been converted to potential energy in the spring.
However, the energy stored in the spring is not kx.
mgh=1/2kx^2?
Yes, physicss
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
