Beat frequency of strobe lights
The discussion revolves around calculating the beat frequency of two strobe lights with a period of 1.00 s, resulting in a frequency of 1 Hz for each light. Over an 813 s interval, the lights fall out of synchronization and then resynchronize, indicating a difference in their frequencies. The term ΔT refers to the time difference between the periods of the two beacons, which affects the beat frequency. The observer notes that the beat frequency changes over time, suggesting that the two lights are not perfectly synchronized despite having the same nominal frequency. Clarification is needed on how to interpret the 813 s interval and its relation to ΔT and beat frequency calculations.
begbeg42
The strobe lights on top of two tall radio towers both have a period of about 1.00 s. When turned on simultaneously, a keen observer notes that during an 813 s interval, the lights gradually fall out of synchronization and then come back into flashing synchronously. What is the interval ΔT between the periods of the two beacons?
abs(frequency1-frequency2)=beat frequency
it would appear that the two strobe lights have the same frequency, frequency=1/period=1 Hz...I don't know what to make of the 813 interval or what exactly delta-T refers to physically
I know the beat frequency involves the superimposition of these two light waves...
i have
299,792,458 m/s=speed of light=frequency(wavelength)
is this relevant?
also is the frequency in this time interval 813 Hz? the period is 1 s i.e. the light completes an oscillation every second so in a 813 s time interval there 813 oscillations?
i know that initially f1-f2=0
then abs(f1-f2) doesn't = 0
then it does again...
however I am not sure what delta-T refers to/asks for... and not sure how to work this
nothing? help please!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
