- 4,458
- 3,265
Really? I didn't know that. Care to give a town?Bystander said:Oh? 'Nother one? Like me?
Edit: Never mind. Just saw Boot Hill on you profile. Now I know. :)
The discussion revolves around the appreciation and revival of old electrical devices and measuring instruments. Participants share their experiences with collecting, restoring, and displaying vintage gadgets, as well as the beauty they find in these items. The scope includes personal anecdotes, technical descriptions of devices, and reflections on craftsmanship and history.
While participants generally appreciate the beauty and craftsmanship of old devices, there is no consensus on the exact age or significance of certain items. Multiple views are expressed regarding the categorization of devices as "old," and the discussion remains open-ended with various contributions and perspectives.
Some discussions reference specific technical details and historical contexts of devices, but there are unresolved questions about the exact age and classification of certain items. Participants also express uncertainty about the functionality of some devices.
This discussion may be of interest to collectors of vintage electronics, enthusiasts of electrical engineering history, and individuals interested in the aesthetics of old measuring instruments.
jim hardy said:Reckpn somebody took them out so they wouldn't leak and corrode ? I was surprised to see them still in gmax's meter. He must live someplace dry...
dlgoff said:Me too. And they look in such good condition that they might still have some charge.![]()
I've spent a bit of time there.dlgoff said:Awesome. I'm a KU grad. Rock Chalk Jayhawk.
[...] Nice to have another Kansan PF member. You, @Evo, and myself are the only ones that I know of.
Regards
PM me if there's anything I can help you with in your studies, etc. Nice to have another Kansan PF member. You, @Evo, and myself are the only ones that I know of.
I took these out of my parents old house. Also the nails are the originals from these insulators. It took some effort to not damage them when removing, as those nails had been in some really old and hard wood. Here's another look at them.sparkie said:I'm curious as to where you got the knobs? Did you take them from old places or do they still manufacture them? Usually they get pretty torn up when demoing.
Now that's a motor. I wonder if it could be made to run again? Here's a "ad" I found from https://www.gracesguide.co.uk/:Windadct said:Machine no 5568, 65 volt, 4.5 amps, 2200 rpm.
stephenkohnle53 said:You should make a gravity fed mercury vacuum pump, ...
In the early days, diffusion pumps used mercury as the operating fluid. As you might imagine, such a thing would be frowned upon today due to the toxicity of mercury vapors. Today, the use of mercury in diffusion pumps is essentially zero.
stephenkohnle53 said:I forget who invented it, ...
stephenkohnle53 said:... do you guys know if you could use a safer material ...
DrClaude said:*speechless*
hmmm...Averagesupernova said:...
This may be nitpicking, but can this thing truly be called 100% electronic considering the coil is technically mechanical?
OmCheeto said:After two hours of googling, I would recommend reading this persons comment from below the video, before doing the same:
Jayyy Zeee
I have a degree in computer science and electrical engineering, have been working professionally in the field for over 20 years, and I have no clue how that coil stores bits.
Nidum said:Google ' acoustic delay line memory ' .
There is a mercury column version as well
OmCheeto said:My brain almost exploded...
OmCheeto said:Are you trying to kill me?
No.Nidum said:Only out of scientific curiosity . Did you record the maximum pressure reached ?
Gauge or absolute... ?Nidum said:Did you record the maximum pressure reached ?
Me too.DrClaude said:*speechless*
Your effort is appreciated.OmCheeto said:... I googled for two hours.
From piano wire to silicon processors. Who would have thought ...? Thanks.Baluncore said:One advantage of delay line memory is that the ALU need only be a one bit serial processor. Another is that CORDIC can be applied to compute the arithmetic +, −, ×, ÷ and √ using shift registers and two serial adders alone. Later, with the addition of diode array lookup tables, all the transcendental functions could be implemented.
https://en.wikipedia.org/wiki/CORDIC
RPN and CORDIC went on to be used in the HP calculator range.
CORDIC was implemented in all the intel 80x87 FPU coprocessors.
Nice. Can you say where it's located?darkwood said:An old abandoned lift control room.
And note the spare lamp. Good stuff.darkwood said:... note the wires are insulated with insulating porcelain beads.
By 1926 the company name changed to The DeVilbiss Company as their product lines continued to expand to include air compressors.
