What Temperature Initiates Bose-Einstein Condensation in a Gravitational Field?
qbslug
For an ideal Bose gas in a uniform gravitational field, at what temperature does Bose-Einstein condensation set in. Gas is in a container of height L.
Normal BEC temperature of an ideal Bose gas not under the influence of gravity is
T = \frac{h^2}{2 \pi m k}\left(\frac{N}{V\xi(3/2)}\right)^{2/3}
I think one must first calculate the density of states for such a system by calculating the volume of phase space and dividing by h^(3N). But I don't know how to calculate the volume of phase space for this situation. I could be wrong of course in this attempt.
\omega = \int^\prime\cdot\cdot\cdot\int^\prime (d^{3N}q \,d^{3N}p) = ?
I have an exam tomorrow in statistical mechanics so I should be able to solve this! :smile:
Normally you calculate the condensation temperature assuming that the particles are free, i.e. E = p^2 / 2m. Now you have a potential energy term in your hamiltonian, V=mgz, where z is the height of the particle in the container. This will influence your density of states and you will get something like:
<br /> N = \int^{\infty}_{p=0} \int^h_{z=0} &lt;n(p,z)&gt; f(p,z) dz dp<br />
for the number of particles, where <n> is the mean occupation number in BE statistics (expressed in terms of p and z), and f(p,z) the density of states, also expressed in terms of p and z.
Do the appropriate approximations in that integral and solve it. Then you can find the condensation temperature.
(Note: I haven't done the calculations but I'm guessing this would be one way to solve the problem, alert me if something seems to be wrong)
yeah the hard part is deriving the density of states for a bose gas under gravity. It doesn't seem to be so trivial.
No, I sat some time trying to solve it and had some serious trouble. How about the density of states as:
<br /> f(p,z)=\frac{4 \pi A zdz p^2dp}{h^3}<br />
(The 4pi comes from integrating out angular dependence in p (spherical coordinates) and the A from the spatial part, except z (x and y, or \rho and \varphi in cylindrical coordinates).)
Chief concern for me is then how to solve the integral. Using that \mu \rightarrow 0 at condensation we have
<br /> &lt;n&gt;= \frac{1}{e^{p^2/2m + mgz} -1}<br />
, right?
So how is the upper limit in the integral for z, L, translated into something dependent on p? We have E=p^2/2m + mgz. I think that can be used to find the upper limit L in the z-integral in terms of p.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
