Beer + Liquid Nitrogen: Why Does It Foam & Popcorn?
In summary, you can't tell the difference between chunks of boiled corn substance and solid foam from beer cooled in LN2.
YaroslavVB
1. If you take beer out of the fridge, dip it for 30 seconds in liquid nitrogen, then open it, it will foam up. Skipping the LNO2 cooling stage, it doesn't foam up, why?
2. Pouring a bottle of beer into Dewar of liquid nitrogen, then letting LNO2 evaporate leaves pieces that are shaped like popcorn. Other substances like grain alcohol leave chunks that look like chunks of water ice...why?
Difficult to know without more detailed tests and a tasting!
1, Does the beer can have a 'widget' - a little gas cylinder inside to simulate the head of a draught pint? It might be that the thermal shock is breakign that open before the can is opened.
2, If you pour foaming beer into LN2 the foam will freeze into a solid foam. The ice left from gain alcohol is either ice, because the alcohol didn't freese or is just frozen grain alcohol+ water mix dependign on how quickly it cooled.
This used to be a way distilling stronger alochol. You would put eg cider/wine outside in freezing weather, ice would form from the water in the drink leaving a higher concentration of alcohol behind. You discard the ice and repeat.
ps Iassume you mean liquid nitrogen LN2 not liquid nitrogen dioxide LNO2!
Now this is some experimental physics I can really get behind...
For the first question, since the submersion time is less than needed to freeze the beer or make a beer slushy, I would guess that small ice crystals nucleate near the walls of the beer can, forming nucleation sites for gas bubbles upon opening and releasing the pressure.
As for the second, I'll go with mgb_phys.
Thanks, the solid foam explanation makes sense, since boiling corn substance exploding would also be a foam in a sense.
BTW, here's the picture of "solid-state beer"
<img src="http://yaroslavvb.com/pictures/lj/08-03-ln2/-10.jpg">
so did you taste the solid state beer or what?
What is liquid nitrogen and how is it related to beer and popcorn?
Liquid nitrogen is a colorless, odorless, and extremely cold liquid with a boiling point of -196 degrees Celsius. When added to beer or popcorn, it causes a dramatic reaction due to its extremely low temperature.
Why does beer foam when liquid nitrogen is added?
When liquid nitrogen is added to beer, it rapidly boils and turns into gas. This gas creates bubbles in the beer, resulting in foam. The colder temperature of the liquid nitrogen also helps to retain the foam for a longer period of time.
Why does popcorn pop when liquid nitrogen is poured on it?
When liquid nitrogen comes into contact with popcorn, it rapidly cools the moisture in the kernels. As a result, the moisture turns into gas and expands, causing the popcorn to pop. The extreme cold also helps to keep the popcorn crisp and crunchy.
Is it safe to consume beer and popcorn treated with liquid nitrogen?
Consuming small amounts of liquid nitrogen-treated beer and popcorn is generally safe. However, it is important to allow the liquid nitrogen to fully evaporate before consuming, as consuming liquid nitrogen directly can be harmful. It is also important to handle liquid nitrogen with caution and follow proper safety protocols.
What are the potential dangers of using liquid nitrogen in food and drinks?
Liquid nitrogen can be dangerous if not handled properly. It can cause severe frostbite and burns if it comes into contact with skin. Ingesting liquid nitrogen directly can also cause serious harm to the digestive system. It is important to use proper safety measures and follow guidelines when using liquid nitrogen in food and drinks.
  • Other Physics Topics
9K
