Beginner C++ - identifier not found
  • Context: Comp Sci
  • Thread starter Thread starter jck_ccc
    Beginner C++
The discussion revolves around a C++ programming issue related to sorting a vector of strings. Participants are addressing syntax errors encountered while transitioning from Java to C++, specifically focusing on the use of member functions within a class and the proper invocation of those functions.
  • Homework-related
  • One participant describes encountering an error indicating that 'sortString' is an identifier not found, which arises from trying to call a member function without an instance of the class.
  • Another participant explains that 'sortString' is a member function of the class 'sorting' and can only be accessed through an instance of that class or with the scope operator.
  • A later reply suggests that if the intention was to create a global function, the header file should be modified to declare 'sortString' and 'compString' outside of the class.
  • Some participants propose using a namespace as an alternative to encapsulating the functions, allowing access via the namespace scope.
  • There is a suggestion to use static member functions if the functions are to remain within the class structure.
  • One participant mentions that if the class is intended to be a data object, an instance must be created to use its methods.
  • Another participant introduces the standard C++ sort routine as an alternative for sorting vectors, highlighting its simplicity and efficiency.
Participants generally agree on the nature of the error and the need for proper function invocation in C++. However, there are multiple competing views on how to best structure the code, whether to use global functions, namespaces, or static members within a class.
Participants discuss the implications of using member functions versus global functions and the specific requirements for accessing class methods in C++. There is also mention of the standard library's sorting capabilities, which may provide a simpler solution.
jck_ccc
Any help is greatly appreciated
I am trying to sort a string of vectors in the proper order. My problem does not involve theory, it involves syntax errors. Moving from Java to C++ is sure a pain..
I have 2 c++ files, sorting.h and sorting.cpp
I keep getting this error:
sorting.cpp(88) : error C3861: 'sortString': identifier not found
Code:
//sorting.h
#pragma once
#include <string>
#include <vector>
using namespace std;
class sorting
public:
	sorting(void);
	~sorting(void);
	vector<string> sortString(vector<string>);
	bool compString(string, string);
Code:
//sorting.cpp
#include "sorting.h"
#include "stdlib.h"
#include <iostream>
#include <algorithm>
#include <vector>
#include <string>
sorting::sorting(void){}
sorting::~sorting(void){}
//implemented with insertion sort in mind
vector<string> sorting::sortString(vector<string> s){
	int current = 1;
	string temp;
	int walker;
	int size = s.size();
	while (current < size){
		temp = s[current];
		walker = current -1;
		while ((walker >= 0) && compString(temp,s[walker])){
			s[walker+1] = s[walker];
			walker = walker - 1;
		s[walker+1] = temp;
		current++;
	return s;
//string comparator made easier
bool sorting::compString(string s1, string s2){
	if (s1.compare(s2) == 1)
		return true;
	return false;
int main() {
	vector<string> vec;
	vec.push_back("asdf"); vec.push_back("abcd"); vec.push_back("zzzz");
	vector<string> vec2 = sortString(vec); //errors out RIGHT HERE
	/*for (int i = 0; i < vec2.size(); i++){
		cout << vec2[i];
	return 0;
The code will sort a vector of type string via insertion sort.
Googled for the past hour, nothing
Looked at old notes, no help
In the line where the error is reported:
you are trying to invoke the function sortString. The error is (correctly) telling you that no such function exists.
But, you say, I did declare and define the member function earlier, with
class sorting
Now, ponder about that...
Done pondering yet?
(If you haven't pondered and just skipped down, then you really should! :-p Working out the meaning of an error message is a good exercise. What I described is exactly the process I would go through when faced with an error)
The problem is that sortString was declared as a member function of class sorting. It only exists in that scope. This means you can only ever access this function in three circumstances:
  1. The call appears somewhere inside the scope of class sorting. (e.g. sorting::compString could use sorting::sortString in that fashion)
  2. The function is invoked as a member function of an instance of class sorting -- just like how you invoked the member function vector<string>::push_back
  3. The function is accessed with the scope operator as sorting::sortString. This is only good for static functions and esoteric pointer-to-member usage.
EDIT: oohhh! That makes sense. I didn't know of such rules. Thank you so much for the help :)
So what's the fix?
Well, what you probably really meant to do is to write a global function. class sorting is not any sort of object or data type -- it's simply a wrapper for a collection of functions. Functions in C++ don't need wrappers like they do in java. You probably just wanted your header file to be
Code:
//sorting.hh
#pragma once
#include <string>
#include <vector>
However, if you really like the wrapper, then the normal way to do it in C++ is through a namespace:
Code:
//sorting.hh
#pragma once
#include <string>
#include <vector>
namespace sorting
And now you can access the functions via sorting::sortString(vec). Or, you could drop the sorting:: by putting using namespace sorting someplace earlier.
If you really, really want it in a class, then you want static members, such as
Code:
//sorting.hh
#pragma once
#include <string>
#include <vector>
class sorting
public:
	static vector<string> sortString(vector<string>);
	static bool compString(string, string);
And the functions can (only) be accessed via something like sorting::sortString(vec).
Oh, and one last oddity. If you really, really did mean for class sorting to be a kind of data object (e.g. maybe each module of your bigger program wants to keep track of its sorting statistics) then your original piece of code is fine. But before you can use any of the sorting routines, you would first have to instantiate an object, such as
vector<string> vec;
sorting sorter;
sorter.sortString(vec);
One last thing: C++ provides a standard sort routine. You would use it by
#include <string>
#include <vector>
#include <algorithm> // for sort
int main() {
vector<string> vec;
// Fill the vector
sort(vec.begin(), vec.end());​
Which sorts the vector based on the < operator (which is correctly defined for string objects). There's another version of std::sort that takes a third parameter which is a "function object" that defines how to compare two objects.
(Okay, I'm really done now with that burst of replies)
I never thought about the std sort. Either way, you have really helped me. I learned so much :) Thank you1
(I used this fix)
Code:
//sorting.h
#pragma once
#include <string>
#include <vector>
