Berry phase in degenerare case
  • Thread starter Thread starter wdlang
    Berry phase Phase
wdlang
Is there anyone familiar with berry phase?
Wilczek and Zee have a classic paper PRL 52_2111
I can not understand their equation (6)
I can not see why the first equality should hold
\eta_a and \eta_b should be orthogonal to each other, but why should \eta_b be orthogonal to the time derivative of \eta_a ?
hmmm... yeah. compare this to the usual berry's phase case where U_{ab} is just a number e^{i\gamma} (e.g., in Sakurai "Modern Quantum Mechanics" p. 465). in that case we have
<br /> \frac{d}{dt} (e^{i\gamma(t)} n(t))=0<br />
where the time dependence in the n(t) (analogous to the \psi_a(t) in the Zee paper) is due to the changing parameter so that
<br /> 0=i\frac{d \gamma}{dt} e^{i\gamma} n + e^{i\gamma} \frac{d n}{dt}<br /> =i\frac{d\gamma}{dt} e^{i\gamma} n + e^{i\gamma} \frac{d \vec \lambda}{dt} \cdot \nabla_{(\lambda)} n<br />
so that (now using normalizaiton of n)
<br /> i\frac{d\gamma}{dt} + \frac{d \vec\lambda}{dt}\cdot (n,\nabla n)=0<br />
I guess, the Zee paper is just generalizing this to the case where instead of
<br /> \eta_a = e^{i\gamma}\psi_a<br />
with just a number for proportionality there is a matrix
<br /> \eta_a=U_{ab}\psi_b\;.<br />
I'm sure this isn't all too helpful, but maybe some other people will have more to say. cheers.
Thanks a lot!
I read Simon's classic paper (PRL 51,2167), and i guess the equation in question reflects the parallel transport
similar eqaution also appears in Simon's paper (on the second page, left upper part)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
