Thank you Hyrkyl,
You wrote:
It's the word complete that has earned the real numbers the nickname "the continuum". (and, sometimes, the term continuum is applied to other complete structures)
Intuitively, all this means is that there are no holes in the real numbers.
So the word "continuum" is just a nickname of the word "complete"
and the word "complete" does not based on rigorous proof, but based on some intuition that some set of "infinitely many objects" is complete.
You also wrote:
If I have a collection of "small" real numbers and a collection of "large" real numbers, there is a real number "between" them.
More precisely, if:
S and T are nonempty sets of real numbers
For any s in S and t in T, s < t
then
There is a real number x such that for any s in S and t in T:
s <= x <= t
That is what, mathematically, the continuum concept is. No "holes".
It is the Dedekind's cut definitions, and it is based on an intuition
that x can close the gap between s and t.
There is no rigorous proof here, but an unproved intuition which believes that this x, which is one of "infinitely many objects", simultaneously can reaches (not approaches) s and t, which are different objects.
This x can reaches s and t iff it has the form of Double-simultaneous-connection object.
p and q are real numbers.
If p < q then
[p, q] = {x : p <= x <= q} or
(p, q] = {x : p < x <= q} or
[p, q) = {x : p <= x < q} or
(p, q) = {x : p < x < q} .
A single-simultaneous-connection is any single real number included in p, q
D = Discreteness = a localized element = {.} ).
Double-simultaneous-connection is a connection between any two different real numbers included in p, q , where any connection has exactly 1
D as a common element with some other connection ( =
C = Continuum = a non-localized element = {.___.} ).
Therefore, x is . XOR .___.
Any
C is not a "normal" real number but a connector (a 1-1 correspondence element) between any two different "normal" real numbers (
D elements).
No single "normal" real number (a
D element) has this property, to be a connector between some two different "normal" real numbers (
D elements).
Between any two different arbitrary close
Ds there is at least one
C, and only
C has the power of the continuum.
By the above definitions, for the first time in Modern Mathematics, there is a clear and sharp distinction between the Continuum and the Discreteness concepts, not by their Quantitative property, but by their
Structural property.
By defining the
double-simultaneous-connection as a legitimate member, I redefine the original lexicographical meaning, back to the Continuum concept, and change the perception of Continuum and Discreteness concepts in Modern Mathematics.
__ = connector
1) Any connector can be translated to a single number, which is its length. In this case I think any arithmetic that works between "normal" real numbers, must work here too.
An example: a__b = b-a = c (a single absolute number)
2) Any length is not a localized element by definition, therefore there can be infinitely many indistinguishable connectors.
An example: 2 = __ = __ = __ = ...
Here we need to develop some arithmetic that deals with uncertainty and redundancy + combination with case (1), and we get case (3).
3) Any connector can be located (by locating exactly one of its end-points) to some localized element (A unique real number). I think this state is some mixing of (1) and (2) cases.
An example: 2__4 = 7__9 = -1002__-1000 = ... = 2
So, my theory can work as case (1) or case (3) system
Any object with length=0 is not a connector but a "normal" real number, therefore {(a,a)} is not a connector but a "normal" real number.
By the way, we can think of a length with a negative value,
and by this we mean that we have a mirror image of - and +
to the real line, where zero is the center of it.
An example: -b__-a = -b - -a = -c , a__b = b - a = c
Please someone can show some trouble in my definitions ?
Thank you.
Organic
