Biasing amplifiers and what they do to the input and output voltages
The discussion revolves around the concept of biasing in amplifiers, particularly in relation to avoiding distortion and ensuring that input and output voltages remain within the linear region of operation. The context includes a specific scenario from a practice exam involving a transistor amplifier's transfer characteristics graph.
  • Homework-related
  • One participant questions the clarity of the initial query regarding the effects of input voltage exceeding the linear region of the amplifier.
  • Another participant emphasizes the importance of correct biasing and suggests that the bias voltage should be set to ensure the average output signal is centered within the output limits.
  • A later post clarifies the context of the discussion as related to a practice exam question about determining the ideal DC voltage for input to avoid distortion, referencing specific voltage ranges for input and output.
  • One participant suggests placing the bias point at a value that results in a DC output halfway up the linear region, indicating that the input waveform's shape is less relevant for linear amplification.
  • Another participant concludes that the midpoint of the amplifier characteristics graph is known as the quiescent point, which adjusts the input AC voltage to remain within the linear region.
Participants express varying levels of understanding regarding biasing and its effects, with some clarifying concepts while others seek further explanation. There is no explicit consensus on the best approach to biasing in this context.
The discussion includes specific voltage ranges and characteristics related to the amplifier but does not resolve the mathematical or conceptual details regarding biasing and distortion avoidance.
therajinator
If we have a input voltage that has a voltage higher then the linear region of the amplifier characteristics graph, what does amplifier biasing exactly do to the wave so there is no clipping, distortion or cut-offs and saturations.
Goodmorning therajinator and welcome to Physics Forums,
This part makes no sense.
This part makes sense on its own
What do you really mean?
Correct biasing is important, of course but you also must not over-drive the input outside the linear region for the output. All things being equal, you would choose the bias voltage so that the average (DC) output signal value is 'half way' in between the limits of the output stage.
That's a very simple answer but is it enough?
okay let me mkae it clearer... this is in regards to a question in a practice vce physics unit 3 exam.
There is a transfer characteristics graph of a transistor amplifier. the linear region of the input voltage is between 1mV and 7mV's. while the output is between 1V and 9V's.
The question asks: an AC signal, whose voltage waveform, i snow fed into the amplifier and an undistorted amplified signal is obtained. What is the ideal DC voltage that should be provided to the input signal to avoid distortion? explain your answer, using the term bias in an appropriate manner.
The input graph looks like a sin wave and has a p-p voltage of 8mV and a frequency of 125Hz.
Thanks
Put your bias point at a value that produces a DC output which is half way up the linear region. You can read that off your graph? (The shape of the input waveform is not relevant if you are dealing with (aiming at) a linear amplifier.
thanks guys I understand now, the middle of the amplifier characteristics graph is called the quiescent point which adjusts the input AC voltage so it's in the linear region.
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 165 ·
12K
