Big-O With Change of Base for Log
  • Thread starter Thread starter TheLegace
    Base Change Log
TheLegace
Hi, I am trying to prove for a>1, b>1 that f(x) = O(log_b(x)) then f(x) = O(log_a(x)).
[Hint: log_b(x) = log_a(x)/log_a(b)).
Assuming |f(x)| <= C|log_b(x)| true for x>k,
then,
f(x) <= log_a(x)/log_a(b)| for all x>1, C=1
then,
log_a(b)*f(x) <= log_a(x) all x>1 C= 1/log_a(b)
f(x) <= log_a(x) x>1 C=1/log_a(b)
f(x) is O(log_a(x))
Now here comes my problems with most big-O problems, since the right side is being divided by something I should just multiply it out to other side:
log_a(b)*f(x) <= log_a(x) I know that log_a(b) on left side would not matter except that it might be
C= 1/log_a(b) and k =1
According to my textbook/notes, C = 1/log_a(b), I still do not see why though, because if I multiply both sides by log_a(b) why C is like dividing both sides log_a(b), if someone could explain it, I would appreciate it thank you very much.
Please Let me Know if this correct, thank you very much.
TheLegace.
then,
then,
f(x) is O(log_a(x))
Sorry, I don't follow that list of inequalities at all.
Can you try it more clearly, perhaps like this.
Given: There exist C and k such that |f(x)| < C |log_b (x)| for all x > k.
Prove: There exist C' and k' such that |f(x)| < C' |log_a (x)| for all x > k'.
Your k' can be the same as k. Your C' will be expressed in terms of C and log_a (b).
Ok...
Prove : a>1, b>1
f(x) = O(log_b (x)) then f(x) = O(log_a (x))
|f(x)| < C |log_b (x) | for all x>k
|f(x)| < |log_a (x) / log_a (b) | for all x>1
then f(x) = O(log_b (x)) = O(log_a (x)) when k=1 C=1/log_a (b)
I am just hoping to know if that's correct.
Thank You Very Much.
TheLegace.
TheLegace said:
Ok...
Prove : a>1, b>1
I don't know how you are obtaining the last line quoted. It is invalid reasoning.
Example:
Let a=10, b=e. Use ln x to denote log base e of x, and let log x denote log base 10 of x.
Let f(x) = 1 + 4 ln x.
Then f is O(ln x), because f(x) < 5 ln x when x > 3. (C=5, k=3.) (Verify with a graph if you want.)
Your next step says f(x) < log x / log e for x > 1. There is no reason for this to be true, and in fact it is false. (Verify with a graph if you want.)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
