Binomial Distribution: Finding Probability with Trials, Success, and X Value
The discussion centers on the misapplication of the binomial distribution for a probability problem involving selecting cars. The user initially used n=7, p=7/15, and X=7, resulting in an incorrect probability. Participants clarified that the scenario does not involve independent trials, leading to the conclusion that the hypergeometric distribution is the appropriate model. An alternative method to solve the problem involves calculating the probabilities sequentially based on the remaining cars after each selection. Understanding the correct distribution is crucial for accurately determining probabilities in this context.
TyErd
I've uploaded a picture of the question.
I need help in identifying the correct number of trials, probability of success and the X value(number of successes)
i'm using the binomial distribution function on the calculator but I've attached the formula just in case
I used n=7, p=7/15 and X=7 which yields me a probability of 0.00482 which is incorrect. The correct answer is 0.000155 but not sure how.
The binomial distribution is inappropriate for this problem. You aren't doing independent trials with replacement. Think about how many ways you can select 7 cars from the 15 and how many ways you can select the 7 fwd cars.
That's not a correct formula to use. How many ways are there to choose 7 cars from 15? Only one of those choices gives you all four wheel drives.
ahh, that's why i keep getting it wrong. Thanks, but if its not binomial, what is it?
It's combinatorics. How many ways to select 7 objects from 15 objects?
It is the so-called hypergeometric distribution.
Note: instead of a combinatorial argument there is another way to get the correct answer. The probability that the first car is fwd is 7/15; that leaves 14 cars, of which 6 are fwd. So (given the first is fwd) the probability that the second is fwd is 6/14, etc, etc.
RGV
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
