Biot-Savard Law: Find Magnetic Field at Center of Loop
  • Thread starter Thread starter lemaire
    Law
The discussion focuses on applying the Biot-Savart law to find the magnetic field at the center of a circular loop created by a wire carrying current I. The initial expression proposed for the magnetic field is (mu_0IL)/(4pia^2), where mu_0 is the permeability constant and a is the radius of the loop. It is noted that this expression can be simplified by substituting L with 2πa. However, there is confusion regarding the correct output from a web software tool, as the current flows in a circular motion before continuing along the x-axis. The participants emphasize the importance of correctly applying the Biot-Savart law to resolve the issue.
lemaire
A single piece of wire is bent so that it includes a circular loop of radius a. A current I flows in the direction of the x-axis . Find an expression for the magnetic field at the center of the loop.
This is a problem involving the integrated Biot-Savard law
You are correct, the Biot-Savart law is the way to go.
well i can't find the right expression.
What have you tried?
this is what i have: (mu_0IL)/(4pia2) with a being the radius and mu_0 being the permeability constant
Looks correct to me. However it can be simplified by noting that L = 2\pi a.
well i am using a web software and the response you and i agreed on is not the right one. In the picture, the current I comes from the left in the x-axis goes in a circular motion and continues in the x-axis again.
