Birds in uniform cirular motion
  • Thread starter Thread starter iluvphys
    Motion Uniform
The discussion revolves around calculating the motion of a bird in uniform circular motion while rising vertically. The bird completes a circular path with a radius of 10 meters every 6 seconds, achieving a speed of 11.2 m/s and an acceleration of 11 m/s². The direction of the bird's acceleration is noted as 0°. The main challenge discussed is determining the angle between the bird's velocity vector and the horizontal, with calculations involving trigonometric functions. Ultimately, the user finds an alternative method to calculate the angle by separating the velocity into components, arriving at a solution of approximately 20 degrees.
iluvphys
Hi friends,
Birds of prey rise up and down on thermals. A bird completes circle of radius 10m every 6s and rises vertically at a rate of 4.0 m/s. Assume uniform acceleration. Find
a)speed of bird relative to ground
b)magnitude of acceleration
c)direction of birds acceleration
d)angle between birds velocity vector and horizontal.
ar = v^2/r
I have got answers for a to c. a) 11.2 m/s b) 11 m/s^2 c) 0°
But I can't really figure out how i can measure the angle.
Could it be tan-1 = 4/11.2 = 19.65?
God in the past few days I have been dreaming about angles.
Please help me.
iluvphys said:
Hi friends,
ar = v^2/r
Please help me.
w = 2*π*f =v/r
v = 2*π*r*f
There is also the acceleration of 4 m/s2 in the z direction don't forget.
As to your dreams, maybe try and forget the acute ones? There are plenty of others out there.
Hi Pion, thanks for the reply.
What do you mean by w = 2*π*f =v/r
v = 2*π*r*f?
What is w, n, and f?
Is this how I get the angle?
Also 4m/s is the velocity not the acceleration :-)
Please help
Yeah.
I got the answer but I did it in a different way.
I separated the vector into its components vx and vy.
vx = 4 vy = 10.47
then: tan-1 = 4/10.47 = 20.something!
Thanks anyway!
