Is BJT Impedance Proportional to Ic?
  • Thread starter Thread starter likephysics
    Bjt Impedance
The discussion centers on the relationship between BJT impedance and collector current (Ic). It clarifies that the transconductance (gm) is defined as gm = Ic/Vt, indicating that gm is proportional to Ic. The impedance of the current source is indeed represented as 1/gm, leading to the conclusion that the current source's impedance is inversely related to the transconductance. Additionally, the input resistance of a diode-connected BJT is expressed as (rbe||1/gm). This reinforces the concept that understanding these relationships is crucial for analyzing BJT behavior in circuits.
likephysics
In the equivalent diagram of BJT, Vbe and rbe represent the base voltage and resistance.
gmVbe is a current source, which represents the current gain.
Since gm = Ic/Vt
Vt/Ic = 1/gm
Does this mean the impedance of the current source is 1/gm ?
I know this sounds a bit weird. It's because of a homework problem posted here -
https://www.physicsforums.com/showthread.php?t=569541
(the input resistance of the diode connected BJT is (rbe||1/gm).
Since gm = Ic/Vt
Vt/Ic = 1/gm
You're confusing up things. gm means trans-conductance. it is derived as gm = dIc/dVbe = Ic/Vt. This Vt is thermal equivalent of voltage and is constant for a particular temperature.
It only means gm is proportional to Ic. And it does mean the current source has 1/gm impedance.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
