Black Body Equations (more of a math prob)
  • Thread starter Thread starter Rob Hal
    Black body Body
The discussion centers on the equivalence of two equations for energy flux radiated from a black body, one in terms of wavelength and the other in terms of frequency. The user initially struggles with the conversion between the two forms and the appearance of a negative sign during differentiation. The solution involves recognizing that the negative sign arises from the limits of integration when substituting variables, which can be resolved by flipping the limits to eliminate the negative. Clarification is provided that the modulus is not strictly necessary for the conversion. Overall, the mathematical conversion between the two equations is affirmed as correct.
Rob Hal
Hi,
In one of my textbooks, I'm given these two equivalent equations for energy flux radiated from a black body, one dependent on frequency, the other on wavelength:
I(\lambda)d\lambda = \frac {2c^2h}{\lambda^5} \frac {1}{e^{(hc/KT\lambda)}-1}d\lambda
and
I(\nu)d\nu = \frac {2h\nu^3}{c^2} \frac {1}{e^{(hv/KT)}-1}d\nu
Now, I'm just trying figure out how are these equations equivalent? At first, I thought it was simple substitution of the relation \lambda = \frac{c}{\nu}, but that doesn't work... so I realize that you have to convert units by differentiating say in this case lambda, and I get the same equations with the exception of a negative sign which I can't see how it cancels.
To be quite honest, I'm just not sure I'm doing the converting right. I'm not exactly sure how to handle the left side of the equation in this case.
Any suggestions or references would be great... Thanks!
Excellent...I knew it was really elementary.
Thank you very much!
the negative sign is due to the limit of the integral
if the lower limit of your lamda is 0 and upper limit is infinite,ie.
\int_{0}^\infty I(\lambda) d \lambda
after you do the substitution, the lower limit of v will become infinite and the upper limit will be 0! ie,
-\int_{\infty}^0 I(v) dv
in order to make the integral looks nicer, we eat the negative sign and flip the limit of the integral:
\int_{0}^\infty I(v) dv
don't worry, your calculation is completely fine...
PS. the modulus is not a must... the web page just don't want to do this argument
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
