Blast furnace and iron ore - help to understand?
  • Thread starter Thread starter late347
    Iron
Blast furnaces are used to convert iron ore into pig iron, which contains a high carbon content, making it unsuitable for many applications. The basic oxygen process (BOP) is essential for producing steel from pig iron because it effectively reduces the carbon content to desired levels, allowing for the creation of various steel alloys. The carbon in pig iron primarily comes from coke, which is necessary for the initial reduction of iron ore. While blast furnaces can produce nearly pure iron, they cannot eliminate the carbon content effectively without additional processing. The BOP introduces oxygen to pig iron, facilitating the removal of excess carbon and enabling the production of steel with specific properties. Other processes, such as the Siemens-Martin furnace, also contribute to steelmaking by allowing for the mixing of pig iron and scrap steel, further refining the final product. The chemistry involved in these processes is complex, requiring precise control of temperature and reactants to achieve the desired material characteristics.
late347
OK, so back in the day, blast furnaces were used to refine the iron ore?
Iron ore concentrate is mechanically and magnetically refined ore ? Refining usually happens at mines, or somewhere around there.
Ore concentrate goes to blast furnace and then you get pig iron.
Why not steel?
I don't understand why converter steelmaking must be used (basic oxygen process) to make steel.
Why not steel out of blast furnace? Or pure iron (let's say almost pure iron something like 99.90%)
I'm kind of baffled by this :oops:
What exactly is so brilliant about the basic oxygen process converter? I should ask, what is the brilliance behind the principle. I can understand that you can quickly make steel but...
Blast furnace uses oxygen... Converter uses oxygen, why not steel out from blast furnace?
:nb)
Chemistry news on Phys.org
Pig iron is the basic material used in the production of wrought iron, cast iron, and steel. 'Steel' refers to an alloy made of iron, carbon, and other elements. There isn't just one recipe for steel: the proportions of carbon and other elements mixed with the iron are varied to make steels having different properties, for example, mild steel, high strength steel, stainless steel, etc. Pig iron typically has a high carbon content, which makes it unsuitable for making many products, which is why the various refining methods were developed: to quickly reduce the high carbon content of large quantities of pig iron, which could then be further modified to make steel and other materials.
http://en.wikipedia.org/wiki/Pig_iron
http://en.wikipedia.org/wiki/Bessemer_process
http://en.wikipedia.org/wiki/Basic_oxygen_steelmaking
Likes Doug Huffman
1. why you don't get wrought iron from blast furnace?
2. why doesn't carbon go away in blast furnace Why not pure iron?
3. open hearth furnace seems to be good invention that is also furnace-based decarburization technology.
4. From my understanding part of the problem is that iron melting point rises to maximum, as the iron percentage grows to 100% (from pig iron percentage of 95% iron)
5. So, instead of only blast furnace, now you need hotter Siemens-martin furnace? More heat , is the cure for problem?
6. Is it necessary to use steel scrap together with pig iron to make "mixture steel" in siemens-martin.
7. Can you make wrought iron with siemens-martin furnace, from pig iron?
For your #1 & #2 questions: When you read the pig iron article, you saw that iron ore is converted to pig iron by heating the ore with limestone. The heat comes from coke (coal product). Coke is mostly what element? Carbon. Pig iron has a high carbon content. Where did the carbon in the steel come from? Coke. So, can you continue to heat in the blast furnace without adding more coke (carbon)? No. So, the steel manufacturers stop the process. And move on to another process that eats up carbon.
Think of steel as iron with small prescribed amounts of impurities. Pig iron has too much, wrought iron too little. BTW mild steel is what almost all of the "wrought iron" work you see in fences and so on.
The steps above are all just chemistry at hellish temperatures. The separation of dross from pig iron leaves carbon in the iron. (You should know why now.) Go back into hell and blow oxygen through the hot pig iron to remove carbon, then add back in prescribed impurities. There are huge numbers of details that have a big impact on steel. Metallurgy is the name of the studies about how these details impact the final product.
heat is possible to be used without carbon going into heated material (it's called pyrolysis)
in that sense you only would use heat energy on the "outside" to break chemical bonds without adding reactants
you don't to it with iron you do pyrolysis (dry distillation) with weaker compounds like hydrogencarbon compounds (oil, tar, wood, plastics etc)
How are you going to reduce iron ore? Just by heating? No, you have to add carbon (as a coke) to the ore directly initially.
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
