How Far Will a Block Slide Up an Incline Before Stopping?
A block with a mass of 23.4 kg slides down a 31.1-degree incline at a constant velocity, indicating a balance between gravitational and frictional forces. To determine how far the block will slide up the incline after being projected with an initial speed of 1.50 m/s, the frictional force must first be calculated using the component of gravitational force along the incline, which is mgsin(theta). The net force acting on the block while moving up includes both the frictional force and the gravitational component, leading to a total acceleration of -2mgsin(theta). The final distance traveled can be found using kinematic equations, taking into account the initial speed and the calculated acceleration. The discussion emphasizes understanding the forces at play and applying kinematics to solve the problem effectively.
bulldog23
A block with mass m = 23.4 kg slides down an inclined plane of slope angle 31.1 o with a constant velocity. It is then projected up the same plane with an initial speed 1.50 m/s. How far up the incline will the block move before coming to rest?
KE=1/2mv^2
W=F*displacement*cos(theta)
I don't really know how to even start this problem. Can someone walk me through it?
Use the coming downward part to find out the frictional force. There are different ways of doing this...
one ways is: work by friction = change in mechanical energy.
once you know the frictional force, you can do the next part.
I haven't ever done anything with mechanical energy. How do you figure that out?
hmmm... actually I was wrong... that's probably not the best way to do the first part... probably best to just use forces...
The net force acting on the block as it slides downwards is 0 (since acceleration is constant). Can you use this to figure out the frictional force?
so then frictional force must be equal but opposite to mg??
bulldog23 said:
so then frictional force must be equal to mg??
not mg... what is the component of mg along the plane?
I'm not quite sure. Is it just g?
no... mg divides into two components... one perpendicular to the plane... one parallel to the plane.
use the angle 31 degrees.
m*cos(theta)
bulldog23 said:
m*cos(theta)
no. what you need is mgsin(theta).
alright, my bad I meant to put mgcos(theta), but I see why it's mgsin(theta). So then I figure that out and divide by 1.5 m/s?
well... mgsin(theta) is the frictional force... the magnitude doesn't change when going up or down... but the direction is different...
So when the object is going up, what is the net force acting on it along the plane?
Take the net force... divide by m... that's the acceleration.
when going up would it be -mgsin(theta)?
yes, that's the frictional force... but you've also got -mgsin(theta) due to gravity... so it's a total of -2mgsin(theta).
so when I plug the numbers in I get -6.74 m. Is this right?
I don't think so. How did you get that?
-2mgsin(theta)/m
bulldog23 said:
-2mgsin(theta)/m
so that's -2gsin(theta). I get -10.12m/s^2
oh ok. So then I divide by the initial speed to get how far up it travels?
bulldog23 said:
oh ok. So then I divide by the initial speed?
No. You need to get the distance... you have v0, a and vf = 0. use kinematics to get the distance.
alright, thanks for the help!
Did you get the distance?
