What Forces Determine the Sliding of a Block on a Wedge?
The discussion focuses on calculating the maximum and minimum horizontal force (F) required to keep a block from sliding on a wedge. The block has a mass of 0.80 kg and rests on a wedge with a mass of 2.0 kg, with a static friction coefficient of 0.40 and an incline angle of 35°. The minimum force can be determined using the equation ma=mg sin(35) - mg cos(35) μ, but the maximum force requires considering the reference frame of the accelerating wedge and the effects of pseudo forces. As the applied force increases, the direction of friction changes based on whether the block tends to slide up or down the wedge. A free body diagram (FBD) is recommended to analyze the forces acting on the block for accurate calculations.
makerfeldt
A block of mass 0.80 kg rests on the inclined surface of a wedge of mass 2.0 kg. The wedge is acted on by a horizontal force F and slides on a frictionless surface.
If the coefficient of static friction between the wedge and the block is µs = 0.40, and the angle of the incline is 35°, find the maximum and minimum values of F for which the block does not slip.
Finding the minimum seems to be pretty straightforward to me. What I have is
Finding the acceleration there, I plug it in for the wedge (as they should be the same if the block is staying put) into ma=F
That gets me the value my homework is asking for, but I have little idea of what to do to find the maximum force.
If the wedge were no moving, would the block slide?
What if you pushed the wedge really really hard?
If you push it just hard enough, it sticks ... what happens if you push it a little harder than that?
That is not the way to approach the problem.
You would be better off working from the reference frame of the accelerating wedge .In this frame a pseudo force F acts on the block in the direction opposite to the frame.So,if we assume the force acts towards right on the vertical face of the wedge i.e the wedge moves towards right ,a pseudo force F acts on the block towards left.
Now,the direction of friction will depend on the magnitude of F .If F is large ,the block will have a tendency to move upwards on the wedge,friction will act downwards.If F is small ,the block will have a tendency to move downwards on the wedge,friction will act upwards.
Draw an FBD of the Block.Mark all the forces.Resolve the forces along the wedge and perpendicular to the wedge .
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
