How Do I Plot a Bode Plot for a Given Transfer Function?
To plot the Bode plot for the transfer function 100/(s^2 + 10s + 100), first factor the denominator to identify the poles, which are critical for the plot. The transfer function has no zeros, indicating it behaves as a low-pass filter (LPF). The damping ratio (ksi) is calculated as 1/2, with a corresponding natural frequency (w) of 10. It's important to post homework-related questions in the designated Homework Help forum for better assistance. Understanding the poles and zeros is essential for accurately plotting the Bode plot.
barneygumble742
hi,
how can i plot the bode plot for this transfer function:
100
s^2 + 10s + 100
i have
2*ksi*w=10
w=sqrt(100)=10
thus, ksi=1/2
-ksi*w=-10/2=-5
so the overshoot will be at ksi which is at 1/2 and my magnitude is 1.
i don't see how i can find my poles and zeros. can anyone help me?
thanks
Just factor the denominator to get your poles. There are no zeros in your transfer function, because s does not occur in the numerator. When you have no zeros, is the transfer function LPF, BPF or HPF?
BTW, homework and coursework questions should be posted in the appropriate Homework Help forum area of the PF. I'll let this stay here for the moment, but please take care to post your homework and coursework questions in the HH forums in the future.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
35K
