When Will the Boeing 787 Finally Take Flight?
  • Boeing
  • Thread starter Ivan Seeking
In summary, the 787 is a new type of aircraft that is made of composite materials. It has many new features that make it different from other airplanes, and it is hoped that it will be a success. The flight test process was delayed by two years, but everything is now going according to plan. I'm nervous about the possibility of problems, but I'm also excited for this new airplane.
  • #71
There are efficiencies to be gained, but not that amount. Aside from better materials letting us burn hotter, one thing I've also heard of it...smart "shapes" or...hell I can't think of what it's called.
Either way, the idea is to have the engine change its shape during the operating range to maintain efficiency, particularly during take-off, climb. How to accomplish this though...whew, no idea.
  • #72
minger said:
Right now I would say things are limited by materials. Better materials will let us run higher temperatures, which will raise efficiencies. Will you see a 50% raise? I don't think so, the thermal efficiencies of those engines are already fairly high, and Cd values are of magnitude ~0.01.
I just don't see from even a macroscopic view you can expect to get an additional 50% from.
Fred: Those are the people that I was speaking of in fact. My graduate adviser split time between the university and Glenn.
I hope I did not give you the impression that I meant 50% improvement in the engines. I meant 50% improvement in the airframe aerodynamics.
  • #73
Note: It is quite interesting how many of you throw in the towel so quickly when presented the facts of the current state in industry.
"Cant be done"..."They would have found it by now"...etc, etc... not a good sign. There is a good example of a car factor that made a stamped part. It took 3 mins to make each part. Someone said he wanted it redone in under a minute. Everyone said he was crazy, impossible. They got it. Then he said, now I want it in under 30 seconds. Again, impossible. After much work, they got each part in under 10 seconds. Don't be those engineers who give up so easily.
Is the 787 a new airplane with composite materials: yes. Does that make me happy: sure. Is it the hottest thing since sliced bread? No.
  • #74
Cyrus said:
I'm not arguing that is the only metric to compare to, nor does the book.
Trick is, selecting metric that suits you you can prove whatever you want. Weight of the EOS camera I am using now is almost identical to weight of the mechanical camera I used 30 years ago, yet it has a zoom lens, works at ISO 100-1600 instead of the one of the film that is loaded, takes 400 pictures and not 36 before "cartridge" has to be changed, allows me to check the picture immediately and so on. Judging from the weight alone there was no progress in the meantime :smile:
  • #77
Cyrus said:
You'll never find a new solution building the same old airplanes. That is the point. The point of thinking is flawed in industry in terms of innovation. They only make small baby steps.
In an industry where it costs millions of dollars just to design and build a protype and millions of more to test it I don't see why you would expect such extreme jumps in technology. Advancement in this kind of technology usually comes from large corporations like Boeing who can afford such endeavors and can see the ability to profit on it in the long run. From a business perspective, wasting millions of dollars on trying to pursue an entirely new technology which might lead to a finished product isn't the best option, regardless of how much better than end product might be. It is smarter to slowly improve current designs one "baby step" at a time allowing the company to have the most advanced technology out there while investing a much smaller amount of money in R&D that could possibly lead to that massive jump.
  • #78
However, your metric is not a good one. The metric I provided is valid (Note: that does not mean its the *only* metric).
  • #79
40 years...let's see something revolutionary. Not excuses.Where are airplanes that use active flow control technologies? Morphing bodies, or any other 'state of the art' technologies.
Is a carbon fiber fuselage with noise reducing engines something to gawk over? I think not.
  • #80
I fly a lot and I don't want to step into some crazy state-of-the-art weird shaped plane. I want tried and true reliability.
  • #81
In time, I'm sure these revolutionary technologies you want to see will come. I just don't think it is reasonable to be expecting them now. I'm not gawking over the 787, I'm just happy to see improvement in the field. These small but significant advances in the technology puts us one step closer to the revolutionary things you long to see.
I think, and correct me if I am wrong, that you are expecting the technology involved in the aerospace field to be advancing at the same rate as the everyday technology around us. The smaller, more everyday, kinds of technology can advance so rapidly because research in these areas is happening all around the world in hundreds of universities and research companies. A lot of these technologies build off each other to allow even further improvement. The technology here is much more specific, expensive, and can not be tested as easily.
  • #82
I might add that if your Blu-Ray burner screws up, you don't lose people by the hundreds in fiery crashes. Some technologies can advance very quickly in part because liabilities in the event of failure are low.
Incremental improvements and well-documented engineering studies can get a plane approved for testing, and help you put it on the path for certification so that it can be mass-produced. When Boeing intends to sink billions into the design, tweaking, and production of a new model, we should applaud their efforts and appreciate the jobs they will create, not Monday-morning quarterback them about a perceived lack of innovation. They have staffs of professionals (engineers, accountants, statisticians, etc) to guide their projects, and they have stock-holders to answer to if they want to keep attracting investment. I wish they'd build a plant in Maine.
  • #83
Is 40 years not "in time"?
I never said any such thing, and your statement makes no sense because many universities around the world do research on aerospace engineering.Where is the revolutionary change as a result of this research? (This is also talked about in the book).
  • #84
Really, I should...Why? ...is their responsibility to make good airplanes, or jobs? I'm not "monday-morning quaterbacking" them, I'm conveying some facts based from a leading aerodynamicist.
It is quite clear that these incremental changes have lead to stagnation in the industry. Prove me wrong.
  • #85
Very good point that I forgot to mention.
  • #86
I think there is more to it. Each technology has it limits. We have not yet found these limits for semiconductor & electronics, so there is plenty of room for advancement. That's not necesarilly the case with planes.
Think about history - we started with wooden frames, canvas and piston engines. If I recall correctly they hit the wall around 200 kts, they were not able to fly faster (even if they were able, it doesn't make my point invalid, read on).
We replaced wood and canvas with metal, and we made planes that were capable of getting around 600 kts. Again, that was technological limit, no amount of tweaking would change the situation (much).
We replaced piston engines and propeller with jet engines - and we get supersonic. Again, this technology has its limits - no idea where they lie, but I would bet Blackbird must be relatively close.
That's why I am not expecting much to change when it comes to planes. Sure, there can be some kind of technological revolution (I would be happy to vitness it) - but there are thousands of people, both professionals and amateurs, trying hard to reinvent the plane. So far most of their inventions were not substantially better than what we already have. Could be that's because we are again close to the technological limits.
Edit:
Perhaps there is no place for it?
  • #87
It sure sounds like you are. Who is this "expert" you keep quoting and why should anyone give a flying fig what his opinions are? He is one person who, apparently lives in a vacuum of a wind tunnel environment. Keep quoting him all you want but it is not reality and it is not keeping the public safety in mind.
BTW...40 years is NOT a long period of time. Perhaps to the Intel/Playstation generation it is but 40 years is a drop in the bucket.
  • #88
That was just my interpretation of your posts, I guess I was wrong, thank you for correcting me. Many universities do research in the aerospace engineering field and may have decent designs on paper but they don't have the ability to build the prototypes that they would have to build in order to get it certified.
  • #89
Considering the author is not from the "Intel/Playstation generation", invalid point. How do you know he 'lives in a vaccum,' when he frequently visits the pentagon to talk with sr. military staff on aircraft performance specifications. Really, your baseless accusations are uncalled for.
Look at the rate of progress of aircraft 40 years after the right brothers. Contrast that to the rate of progress 40 years after the B-707.
  • #90
I'm not sure where you are getting your information from, but Universities don't design aircraft.
  • #91
Edit:
Finally, someone is hot on the trail. Each quantum leap in technology is due to a key enabling technology. For the helicopter, it was the turbine engine. For aircraft today, there needs to be a key technology that will allow for a big leap in performance. This is where the money should be spent - finding "that" technology. I say it in quotes.
  • #92
Speaking of quantum leaps... Each next energy level is closer to the previus one, so the differences become smaller and smaller, and finally once you try to jump too high you will find you are no longer part of the atom :wink:
  • #93
Few years ago students from Warsaw Technical University have built a model aircraft that won some international competition - highest payload for the model weighting under xx kg or something like that, I don't remember exact details. You think they have skipped the design stage?
Now, designing and building a model is not the same as designing and building full scale aircraft, but that's a good way of testing new ideas. So it is not entirely impossible and it is done all the time.
  • #94
I'm not talking about model airplanes: I was hoping that would have been clear by the topic of the thread. I am aware of how aircraft are designed, as I have done wind tunnel testing on scale models. However, my point still stands.
When your company sells "Legacy" aircraft, that's the problem.
  • #95
Your wind-tunnel expert has to deal with models - that's the nature of the work. Boeing has to deal with real airplanes. Given a shift from aluminum skin to carbon composites with all the changes that must entail regarding attachment of the skin to the airframe, and the improvements in fuel-efficiency and noise reduction that they claim with the new design, it seems a bit presumptuous for a newly-minted engineer to disparage their work.
As a process chemist and troubleshooter in a new state-of-the-art pulp mill 3 decades ago, I had to help several new engineers learn the difference between theory and practice AND relate that to the realities of business. A couple of percentage points of efficiency in an energy-intensive business could make your bosses into heroes and ensure your job forever. As the lead operator and troubleshooter on the world's most advanced paper machine a few years later, I was fighting that same battle with a whole new batch of engineers, some of which had cut their teeth on equipment that was "cutting edge" about 50 years prior. Not easy.
This example may seem 'way OT, but it is not. You cannot hope to extrapolate your educational experience and your limited professional experience to an entire field of endeavor, nor critique a very large successful corporation with a track record like Boeing's without some really solid professional references to back you up. You don't like the new Boeing offering? Fine, but you might want to be prepared to offer some actual reasons, because right now, you are sniping and whining.
I hope they get the craft tested and certified for production (even if it is a bit late) and capture their targeted share of the market. We can certainly use the jobs, and every foreign-based carrier that orders units helps run down our trade deficit.
  • #96
Who said I have a 'wind-tunnel expert'? I never said any such thing. In addition, did I not give you a source with a graph of the evolution of performance over the last 40 years of aircraft. If you have trouble interpreting it, let me know. If you have data that shows otherwise, please provide it as I would be interested in seeing it.
And that's exactly the wrong mindset if you want to come up with revolutionary, and not evolutionary aircraft designs. Thank you for making my point.
It was based on my readings of a leading aerodynamicist. It's not my "snipping and whining." Did you miss that in my post? I was pretty clear about it. Go back and reread it if necessary, as I generally don't like being misquoted.
That has nothing to do with the technical aspects, which is what I'm talking about.
  • #97
Who is he? If he is doing nothing but bashing progress, then he is definitely in the minority, especially in the industry. Tell me who "he" is and I would be more than happy to look at what he considers to be worthy. Also tell me what advancements he is responsible for himself. Or are we just talking another academic that does nothing but write papers?
Most of those advancements after Kitty Hawk were due to engine development. Since the 707 we have had many advances although mostly military. So what exactly is a development that is up to your standards.
  • #98
Cyrus said:
...Universities don't design aircraft.
You just made the most prolific point of this debate.
  • #99
I am referencing this book:
https://www.amazon.com/dp/0966955315/?tag=pfamazon01-20
Note: this was written before the 787, so I am basing what I said mostly on what is contained within it but still applies in here. The spirit still holds true.
  • #100
Cyrus said:
Yeah, because its not like a leading aerodynamicist wrote the book I scanned for you. Or that I gave you something I was told by an aerodynamicist at boeing. Perhaps we should do more reading on this subject?
OK, without further attribution (since it was not provided by Cyrus), here is the "authority" on which he bases his claims. Pretty lame.
  • #101
Again, one chart and a silly equation that you are saying debunks a 15+ million dollar aircraft program. Yeah, right.
And this comes from your vast experience in industry and in getting designs to the marketplace or your parroting of one person's technical opinion?
  • #102
Are you going to provide me with data that shows where this airplane is "spectacular"? I'm waiting.
I think you can take a lot from the early team at skunk works, who designed things to be great, not to make money. As a result, they build fast, cheap, amazing airplanes under budget and under time. Meanwhile, you're happy about 20% increases in performance? ...while being 2 years delayed?...
That "silly equation" is quite important. I suggest you look at it harder and interpret what it means.
  • #103
Cyrus said:
I think you can take a lot from the early team at skunk works, who designed things to be great, not to make money. As a result, they build fast, cheap, amazing airplanes under budget and under time. Meanwhile, you're happy about 5% increases in performance? ...
A friend's father was involved in the design and implementation of the Blackbird. If you think that plane was cheap, you might need a refresher course in economics.
  • #104
By cheap, I mean within its designated budget. If I want a lesson in economics, I'll read an economics book. :wink:
  • #105
All right you two, go away! I have to do work. I'll continue this discussion tomorrow. :smile:
  • Aerospace Engineering
  • STEM Academic Advising
  • General Discussion
16K
