Boil by increasing temperature or reducing pressure?
The discussion centers on the efficiency of boiling a substance by either increasing temperature or reducing pressure in a reactor setup. It highlights that typically, substances flash when pressure is reduced, but heat is still necessary for continuous boiling. Participants express confusion about the process flow, questioning whether a distillation step is indeed required between two reactors. A thorough analysis of both methods is recommended to determine the most cost-effective approach for the specific conditions outlined. Ultimately, the choice between increasing temperature or reducing pressure depends on the detailed requirements of the distillation process.
goggles31
Which one is cheaper to do if I have a reactor at 45 bar, 80C and wish to distill a substance before it enters another reactor at 15 bar, 150C?
Funny stuff you're dealing with ! What is it ? I don't get the complete picture, I think. Usually things flash when the pressure is reduced. You sure you mean a distillation step between two reaction steps ? And then the bottom product goes to the second reactor ?
Reducing pressure alone will not cause continuous boiling: you still need heat.
You will need to do a real analysis of the potential processes to determine which fits your needs better.
