Book moving and friction problem
  • Thread starter Thread starter FizixFreak
    Book Friction
Moving a book on a table requires different forces for initial movement and for maintaining uniform velocity. The force needed to start moving the book is 3.2 Newtons, which is determined by the coefficient of static friction. Once the book is in motion, a reduced force of 2.4 Newtons is sufficient to keep it moving at a constant speed, as this is based on the coefficient of kinetic friction. Typically, static friction is greater than kinetic friction, meaning it takes more force to initiate movement than to maintain it. Understanding these frictional forces is crucial for solving related physics problems.
FizixFreak
A BOOK LIES ON A TABLE WHICH HAS WIEGHT OF 8 NEWTON THE COEFICIENT OF STATIC FRICTION BETWEEN THE SURFACES IS 0.4 AND COEFICIENT OF KINETIC FRICTION IS 0.3 (1)HOW MUCH FORCE IS REQIURED TO MOVE THE BOOK(2)HOW MUCH FORCE IS REQUIRED TO MAKE IT MAVE WITH UNIFORM VELOCITY
ACCTUALLY I HAVE SOLVED THE QUESTION I JUST WANT TO KNOW THAT IS MOVING THE BOOK AND MAKING THE BOOK MOVE WITH UNIFORM VELOCITY REQUIRE SAME FORCES?
(please don't shout :redface:)
No, the forces are different.
What solutions did you get? :confused:
The force require to "make it move" (initially) is proportional on the static friction. The force necessary to then make it move with uniform velocity is proportional to the kinetic friction. You do the same calculation but in the one case, use static friction and in the other kinetic friction.
Typically, as here, the coefficient of static friction is larger than the coefficient of kinetic friction so it takes less form to keep an object moving, once you have it started, than it does to make start moving in the first place.
thank you very much now i realized what a silly question i just asked thankx man
the answer to (1)is 3.2 and the answer to (2)is 2.4/SIZE]
That's right!
3.2 N is needed to get it moving, but once it's moving, the force can be reduced to 2.4N for steady speed. :smile:
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
