Boolean Algebra - Simplest POS / SOP
The discussion focuses on understanding the simplest forms of Product of Sums (POS) and Sum of Products (SOP) in Boolean algebra. The user seeks clarification on whether their expression for POS, (A+B+C')(A+B'+C)(C+D), is already in its simplest form or requires further minimization. It is clarified that having A, B, C, and D in every term is unnecessary for simplification, as the provided expression is already simpler than a product of maxterms. Additionally, the user questions if the expression ABC+BD+A'BCD' represents a minimal SOP, acknowledging that while terms can be combined to reduce literals, they are considering the expression as is. Understanding these concepts is crucial for mastering Boolean algebra simplification techniques.
xenocid3r
Hey all
So i just need some clarification, though I hope I am posting in right section (this is not a HW Q)
I was told to find the simplest Product of Sums(POS) and Sum of Products(SOP)
1st 2nd 3rd
now i know that POS mean that (A+B+C')(A+B'+C)(C+D). Is the simplest form of this expression is that I need to have ABCD in every term there. or is this form is already simplest. Do I need to add D to the first 2 terms and A and B to the 3rd?
I mean do i need to use the distributive law in order to minimize an expression like that?
I was trying to look in my textbook but could understand it very clearly. Would appreciate if someone can explain that to me.
P.S. the expression above is not part of the homework, I just gave something random. I am trying to understand the concept and not to solve it.
Thanks for anyone who will try to help me here
Xeno
No, if you had A, B, C, and D in every product term, then the expression would be a product of maxterms. The expression you posted is simpler than the equivalent product of maxterms.
Thanks for the reply.
another thing. in a sum of products, can I have ABC+BD+A'BCD'. Is this consider a minimal SOP? I know I can combine the above terms to get rid of few literals. but just for the sake of it, let's assume it isn't possible.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
