Boundary conditions of a bending plate
The discussion revolves around determining the boundary conditions for a bending plate subjected to its own weight. The plate is supported at specific points and is expected to deform elastically, with a focus on the right half of the plate.
  • Participants explore the appropriate boundary conditions for the plate, specifically at the free end and the midpoint. There is a discussion about the implications of the plate's deformation and the significance of bending stress.
Participants have identified potential boundary conditions, such as zero shear force and zero bending moment at the ends of the plate. Clarifications regarding the definitions of the ends of the plate are being discussed, indicating an ongoing exploration of the problem.
There is some ambiguity regarding the interpretation of the plate's ends, particularly whether it refers to the full length or just the right half. The sagging of the plate beneath the x-axis is also noted as a relevant detail.
kosovo dave
I'm trying to find the boundary conditions for the following problem:
A plate with length 2L is placed on supports at x = L/2 and x = - L/2. The plate is deforming elastically under its own weight (maximum displacement bowing up at x = 0). Both ends of the plate are free boundaries.
The goal is to eventually solve the equation DW'''' = q(x) for the right half of the plate (x > 0).
D is the flexural rigidity $$\frac{Eh^3}{12(1-\nu^2)}$$
E is Young's Modulus, ν is Poisson's ratio, h is the thickness of the plate, and q = -ρgh.
Since the right end of the plate is free, I think the two boundary conditions there are DW''' = 0 (shear force) at x = L and DW'' = 0 (bending moment) at x = L. What are the quantities I should be considering for the boundary conditions at x = 0? I feel like one of them is bending stress.
The bending moments and the displacements are zero at both ends. The reaction forces and shear forces are not.
By "ends" do you mean of the full plate (x = -L and x = L) or the half-space (x=0 and x = L)? I should also clarify that the ends of the plate (x = +/- L) sag beneath the x-axis.
kosovo dave said:
Oh. I missed this when I was visualizing the system. Yes, the boundary conditions you proposed are the correct ones to use: zero shear force and zero bending moment at both ends.
