Boundary Layer Theory: Displacement & Momentum Thickness Explained
Displacement thickness and momentum thickness are key concepts in boundary layer theory, representing the effects of the boundary layer on mass and momentum flow in viscous fluid flows. Displacement thickness quantifies how much the wall would need to be moved to maintain the same mass flow rate as in an inviscid case, while momentum thickness measures the impact on momentum flow. The divergence of streamlines away from the body in the boundary layer is necessary to conserve mass, as the presence of the boundary layer alters the flow characteristics. Both thicknesses are integral to understanding the behavior of boundary layers and are calculated using specific integrals. These concepts are crucial for analyzing viscous flows around surfaces.
mrajkumar
Hi,
could you tell the physical meaning of the displacement and momentum thickness of a boundary layer.And why the stream line diverges away from the body in the boundary layer to conserve mass?
update - I wan't sure about what you meant by momentum thickness, but thanks to boneh3ad's next post, it's explained there.
Link to flat plate article:
flat plate.htm
The convexity or concavity of the surface is irrelevant for the question at hand, and by stating that this is a question about boundary layers automatically means this is a viscous flow.
The displacement thickness (##\delta_1## or ##\delta^*##) is a measure of the effect of the boundary layer on the flow of mass in a fluid. Essentially, you can solve the flow inviscidly and come up with a certain overall mass flow rate. Then solve the same flow accounting for the boundary layer, and the mass flow will be slightly smaller. The displacement thickness is the distance the surface would have to be displaced in order that the mass flow in the inviscid case would be the same as that in the viscous case with the original wall position. In essence, it is the distance the wall must move in order to get the same outer flow (inviscid) answer without solving for the boundary layer.
\delta^* = \int\limits_0^{\infty}\left(1 - \dfrac{u}{U_{\infty}}\right)dy.
The momentum thickness (##\delta_2## or ##\theta##) is similar, only it deals with the flow of momentum rather than mass. It shows up in the momentum integral boundary layer equation (as does ##\delta^*##).
\theta = \int\limits_0^{\infty}\dfrac{u}{U_{\infty}}\left(1 - \dfrac{u}{U_{\infty}}\right)dy
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
